Request ag35e firmware - LTE Not Working on LG U+ (Korea)
Hello
I have a problem with proceed with the OTA provisioning. Here’s what I did, problem, and require
1. Background & Objective
  • Module: Quectel AG35e
  • Network: LG U+ (South Korea)
  • Objective: M2M eSIM OTA Provisioning (via BIP) using LG U+ SM-DP+ server.
  • Reference Document: “Quectel SIM OTA Provisioning Process for Korea Network”
2. Current Status (Network & Bootstrap OK) We have successfully attached to the LG U+ Bootstrap network. The hardware and network configurations are completely fine.
  • AT+CIMI returns 450069115360647 (Pseudo IMSI successfully read).
  • AT+CGDCONT? confirms the APN is correctly set to ota.lguplus.co.kr.
  • AT+CEREG? returns +CEREG: 0,1.
  • AT+CGPADDR=1 returns a valid IP (10.14.235.1).
  • LG U+ has confirmed that the operational profile is ready on their SM-DP+ server.
3. Problem & Symptoms Even though the network is perfectly ready, we cannot proceed with the OTA provisioning because the firmware does not recognize the STK/OTA commands.
  • With FW AG35EVDR08A03T4G:
    • AT+QCFG="stk" → returns ERROR
    • AT+QCOTA → returns ERROR
  • With FW AG35EVDR08A19T4G (Provided recently by support):
    • The STK and QCOTA commands STILL return ERROR.
    • Furthermore, this firmware breaks the basic network connection (AT+CEREG? returns 0,4 instead of 0,1).
4. Our Request We DO NOT need the latest “Global Standard” firmware. We specifically need the LG U+ Custom Firmware that explicitly supports the BIP feature.
Please provide the following:
  1. The exact LG U+ Custom Firmware build where AT+QCFG="stk" and AT+QCOTA commands are fully enabled and supported.
  2. The appropriate QFlash tool and flashing guide if there are any specific instructions for this custom firmware.
Or if there’s any firmware that can support BIP feature, please send it to my e-mail
Looking forward to your prompt support. Thank you.
I have not heard custome firmware as you mentioned. Could you please provide more details? When/Where have you used such firmware build?
