Request ADB and Root Login Password
Could you please provide the login password for my EG21-AUX?
Here is the login prompt I met.
mdm9607 login: root
quectel-v : v1.0
quectel-ID : 33178484
Password:
For security reasons the community won’t be able to provide root/ADB passwords. If you legitimately own that EG21-AUX module, the correct and safe routes are:
  1. Check the module’s quick start/user manual or the firmware release notes — manufacturers sometimes document default credentials (if any) there.
  2. Contact Quectel support or your vendor with the module’s serial/IMEI and proof of purchase; ask them for the proper recovery procedure or the official firmware/flash tools.
  3. If the device shipped with a carrier image, ask the carrier/vendor — they sometimes lock devices and control credentials.
  4. Don’t post any passwords or sensitive console output publicly here — share them privately with official support only.
If you want, I can help you draft a short support request to Quectel (include model, quectel-ID shown in your prompt, firmware version if known, and where/when it was purchased). Example template:
Subject: Request for ADB/root access recovery — EG21-AUX (quectel-ID: 33178484)
Hello Quectel Support,
I have an EG21-AUX module (quectel-ID: 33178484) and I need assistance recovering ADB/root access. The login prompt shows mdm9607 login: root and quectel-v : v1.0. The device was purchased from [vendor] on [date]. Please advise the official recovery procedure or any required files/proofs. Thank you.
Hello,please check the passcode, thanks~
Could you please provide the login password for my EC25-E?
quectel-v : v1.0
quectel-ID : 20456995
mdm9607-perf login:
Hi! Thanks! I need two more root login passcodes — both of them are EG21-AUX, with Quectel IDs 28191675 and 27282805.
I can’t log in with the code you kindly provided me. What am I doing wrong? Maybe I need a special firmware version?
ATI
EC25
Revision: EC25EFAR06A11M4G
msm 202101121539 mdm9607-perf /dev/ttyHSL0
mdm9607-perf login: root
quectel-v : v1.0
Password:
hello,please try this passcode, if any issue, please contact us, thanks~ @polukot
Hi, i have a EC21 and need the root login password.
I already unlocked ADB but the shell login password is not the same.
ATI
EC21
Revision: EC21EFAR06A05M4G
quectel-v : v1.0
quectel-ID : 27954364
Thanks!
hello, please check the passcode, thanks~
Thanks for the reply!
That is the password i used to unlock ADB, but for the login with user “root” i get “Login incorrect”.
@AnnaLiu Hi Anna, could you please help to check this issue, thanks~
Could you please provide the login password for my EC25-EU?
My quectel-ID is 12731205
Hi, is there any update?
hi @Jonas_IM2M ,
Sent the user guid to your email, pls check.
Hi, the passcode 2b6ZA5gKUG9lCKB dont work for me.
ADB Login: user=root passcode=2b6ZA5gKUG9lCKB => fails
Please help me!
Can I have the password ?
quectel-v : v1.0
quectel-ID : 10405265
mdm9607-perf login:
Hello,please put the passcode in “” English character and try again, thanks~
