Thank you for you answer @Puck-Q .
Unfortunately, that did not work. The GPIO state does not change when I control it from userspace. It appears to no longer be controlled by the modem, because the LED no longer turns on when the modem is connected, like it did before.
I changed the model_cfg file, you can see it being loaded in kernel boot log below with value AD0101.
[ 0.844164] [modem_cfg] open sucessfully
[ 0.844529] [modem_cfg] read_buf A00101A10101A20101A30101A40101A50101A60100A70101A80100A90101AA0101AB0100AC0100AD0101AE0100AF0100MQ
[ 0.844564] [modem_cfg] smem copy length=99
[ 0.844568] [modem_cfg] smem alloc sucessfully
Performing the steps you identified to control the GPIO from userspace:
/sys/class/gpio # ls
export gpiochip896 gpiochip912 gpiochip916 unexport
/sys/class/gpio # echo 898 > export
export gpio898 gpiochip896 gpiochip912 gpiochip916 unexport
/sys/class/gpio # cd gpio898/
/sys/devices/platform/c440000.qcom,spmi/spmi-0/spmi0-01/c440000.qcom,spmi:qcom,pmx65@1:pinctrl@8800/gpiochip2/gpio/gpio898 # echo out > direction
/sys/devices/platform/c440000.qcom,spmi/spmi-0/spmi0-01/c440000.qcom,spmi:qcom,pmx65@1:pinctrl@8800/gpiochip2/gpio/gpio898 # cat direction
out
/sys/devices/platform/c440000.qcom,spmi/spmi-0/spmi0-01/c440000.qcom,spmi:qcom,pmx65@1:pinctrl@8800/gpiochip2/gpio/gpio898 # echo 1 > value
/sys/devices/platform/c440000.qcom,spmi/spmi-0/spmi0-01/c440000.qcom,spmi:qcom,pmx65@1:pinctrl@8800/gpiochip2/gpio/gpio898 # cat value
1
/sys/devices/platform/c440000.qcom,spmi/spmi-0/spmi0-01/c440000.qcom,spmi:qcom,pmx65@1:pinctrl@8800/gpiochip2/gpio/gpio898 # echo 0 > value
0
I did notice that 898 is mentioned in the kernel boot log, not sure if that is relevant to this issue?
[ 0.384062] quec_key c440000.qcom,spmi:qcom,pmx65@1:ql-pwrkey@8A00: key pmx65_gpio3: gpio=898; irq=101; code=116, wakeup=1, dbc=15
[ 0.384203] quec_key c440000.qcom,spmi:qcom,pmx65@1:ql-pwrkey@8A00: key pmx65_gpio14: gpio=909; irq=102; code=408, wakeup=1, dbc=15
Thank you.
