We are working on a solution with a remote SIM bank.
In the Quectel modem end, we have a Microchip Controller that the Quectel modem sees as the SIM card. This Controller is in 3.3 volt technology. Is it a problem that we connect the 3.3 volt signal to the data-connection for the SIM (normally 3.0 volt), or do we need a voltage level shifter?
I also have a question regarding the baud-rate. We connect the SIM direct to the modem and measures, the clock signal from modem to SIM is 4 MHz, the baud-rate the SIM is using seems to be in the neighborhood of 3000 according to my measurements. Shouldn’t the baud-rate be 9600?
