Regarding the positioning issue of EC200ACNGA-N06-MN0CA
Dear Quectel Support Team,
I am currently in the process of integrating the EC200A Module with the RK3566 platform. However, I have encountered some challenges in locating the GNSS Drivers, specifically “gps.default.so”
Here are some additional details about my setup:
  • Device: RK3566
  • Android Version: 11
Error in gps_ql:
`05-25 17:42:37.218   281   281 D gps_ql  : get android version:30
05-25 17:42:50.758   281   281 D gps_ql  : ql_gps_get_extension(name=gps-xtra)
05-25 17:42:50.758   281   281 D gps_ql  : ql_gps_get_extension(name=agps_ril)
05-25 17:42:50.759   281   281 D gps_ql  : ql_gps_get_extension(name=agps)
05-25 17:42:50.759   281   281 D gps_ql  : ql_gps_get_extension(name=gps_navigation_message)
05-25 17:42:50.759   281   281 D gps_ql  : ql_gps_get_extension(name=gps_measurement)
05-25 17:42:50.759   281   281 D gps_ql  : ql_gps_get_extension(name=gps-debug)
05-25 17:42:50.760   281   281 D gps_ql  : ql_gps_get_extension(name=gps-debug)
05-25 17:42:50.760   281   281 D gps_ql  : ql_gps_get_extension(name=gnss_configuration)
05-25 17:42:50.760   281   281 D gps_ql  : ql_gps_get_extension(name=gps_geofencing)
05-25 17:42:50.762   281   281 D gps_ql  : GPS DRIVER VERSION: Quectel_Android_GPS_Driver_V2.2.9
05-25 17:42:50.764   281   281 D gps_ql  : config path prop not found
05-25 17:42:50.765   281   281 D gps_ql  : [] [rild-nmea] [0]
05-25 17:42:50.765   281   281 D gps_ql  : MODULE_TYPE:
05-25 17:42:50.765   281   281 D gps_ql  : QL_GPS_CHANNEL:rild-nmea
05-25 17:42:50.765   281   281 D gps_ql  : BAUD_RATE:0
05-25 17:42:50.766   281   281 D gps_ql  : init_times = 0, s->init = 0
05-25 17:42:50.767   281   281 D gps_ql  : init_times = 0
05-25 17:42:50.767   281   281 D gps_ql  : ql_gps_state_init start
05-25 17:42:50.767   281   281 D gps_ql  : Android gps will read from 'rild-nmea' channel
05-25 17:42:50.767   281   281 D gps_ql  : gps state initialized
05-25 17:42:50.767   281   840 D gps_ql  : Error connecting rild-nmea (Connection refused)
05-25 17:42:50.767   281   840 D gps_ql  : fail to open GPS channel <rild-nmea>!
05-25 17:42:50.768   281   281 D gps_ql  : ql_gps_xtra_init(callbacks=0x6fd47792e0)
05-25 17:42:50.768   281   281 D gps_ql  : ql_gps_Xtra_start: gpsXtraCallbacks=0x6fd47792e0
05-25 17:42:50.770   281   281 D gps_ql  : ql_loc_agps_ril_init[37]--enter!
05-25 17:42:50.770   281   281 D gps_ql  : ql_loc_agps_ril_init[38]--leave!
05-25 17:42:50.771   281   281 D gps_ql  : ql_gps_cleanup()
05-25 17:42:50.772   281   281 D gps_ql  :  report_gps_state   enter
05-25 17:42:50.772   281   281 D gps_ql  : reportStatus GPS_STATUS_SESSION_END
05-25 17:42:50.772   281   281 D gps_ql  :  report_gps_state   leave
05-25 17:42:50.772   281   281 D gps_ql  : reportStatus to GPS_STATUS_ENGINE_OFF
05-25 17:42:50.772   281   281 D gps_ql  : ql_gps_state_done[227]--enter!
05-25 17:42:50.772   281   281 D gps_ql  : ql_gps_state_stop[240]--enter!
05-25 17:42:50.772   281   281 D gps_ql  : ql_send_to_target() start
05-25 17:42:50.772   281   281 D gps_ql  : ql_send_to_target() end
05-25 17:42:50.773   281   281 D gps_ql  :  report_gps_state   enter
05-25 17:42:50.773   281   281 D gps_ql  : reportStatus GPS_STATUS_SESSION_END
05-25 17:42:50.773   281   281 D gps_ql  :  report_gps_state   leave
05-25 17:42:50.773   281   281 D gps_ql  : reportStatus to GPS_STATUS_ENGINE_OFF
05-25 17:42:50.777   281   841 D gps_ql  : gps thread running
05-25 17:42:50.796   281   281 D gps_ql  : GPS DRIVER VERSION: Quectel_Android_GPS_Driver_V2.2.9
05-25 17:42:50.796   281   281 D gps_ql  : config path prop not found
05-25 17:42:50.796   281   281 D gps_ql  : [] [rild-nmea] [0]
05-25 17:42:50.796   281   281 D gps_ql  : MODULE_TYPE:
05-25 17:42:50.796   281   281 D gps_ql  : QL_GPS_CHANNEL:rild-nmea
05-25 17:42:50.796   281   281 D gps_ql  : BAUD_RATE:0
05-25 17:42:50.797   281   281 D gps_ql  : init_times = 1, s->init = 1
05-25 17:42:50.797   281   281 D gps_ql  : ql_gps_xtra_init(callbacks=0x6fd47792e0)
05-25 17:42:50.799   281   281 D gps_ql  : ql_loc_agps_ril_init[37]--enter!
05-25 17:42:50.799   281   281 D gps_ql  : ql_loc_agps_ril_init[38]--leave!
05-25 17:42:51.769   281   840 D gps_ql  : Error connecting rild-nmea (Connection refused)
05-25 17:42:51.769   281   840 D gps_ql  : fail to open GPS channel <rild-nmea>!
05-25 17:42:52.770   281   840 D gps_ql  : Error connecting rild-nmea (Connection refused)
05-25 17:42:52.770   281   840 D gps_ql  : fail to open GPS channel <rild-nmea>!"`
I would greatly appreciate your assistance in resolving these issues or guiding me on where to obtain the correct drivers for this configuration. Your expertise in this matter would be invaluable in getting this integration to work seamlessly.
Thank you for your prompt attention to this matter.
Best regards,
May I ask if you have a mini PCIe interface? If so, please execute AT+QGGPOWOWER=1.
