Reducing current consumption M66
Hello all,
I am using an M66 module with a rather small 200mAh 3.6V lithium cell in a portable device. When I try to transmit data using GPRS, (using CFUN=1), the battery voltage drops just slightly below 3.3V and the module turns off.
Is there a way to limit the current surge? I came across the RF Test application note and it talks of a command called AT+QMAXTXPWR command. Can it be used to reduce TX power so that the current surge is lower in magnitude?
Thank you,
Regards
