RedCap RG255C-GL modem: Wrong DNN is transmitted to the Core Network
Hi together!
We are working with the Quectel RG255C-GL RedCap 5G modem and have a problem with the activation of the PDP context. As a result, the modem is sending the wrong DNN to the 5G core network during the PDU establishment request procedure (CID 2 with DNN “ims” is used instead of CID 1 “internet”). We configured the modem using the following AT commands:
  1. Firmware version:
    $ AT+GMR
    RG255CGLABR01A04M4G
  2. We added a PDP context with CID 1 as shown below:
    $ AT+CGDCONT?
    +CGDCONT: 1,“IP”,“internet”,“0.0.0.0”,0,0,0,0,“”,0
    +CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0,“”,0
    +CGDCONT: 3,“IPV4V6”,“sos”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1,“”,0
  3. The CGACT command confirms us that the PDP context is available.
    $ AT+CGACT?
    +CGACT: 1,0
    +CGACT: 2,0
    +CGACT: 3,0
  4. However, when trying to activate the PDP context, the modem returns an error:
    $ AT+CGACT=1,1
    +CME ERROR: 30
Is there anybody who can has the same problem? Or does anybody know a solution?
Note: The same procedure works for us using the Quectel RM520N-GL modem using the same SIM card. Also the PDP context activation works without problems.
Dear @nk2025
Could you help to confirm whether device register on network?
Dear @silvia,
indeed, we can confirm that the modem registers on the network. However, after a successful registration, the modem is still sending further PDU session requrest messages to the core network (in our case the PDP context with cid 2 “ims”). I attached a Wireshark capture file where you can see the described behaviour (2025.11.13__RG255C-GL-registration.tar (6.5 KB)).
Is this behaviour of sending further PDU session requests “normal”?
Dear @nk2025
After registration, do you have any other operations?
What do you mean of sending further PDU session requests?
