Hi, I’m trying to get sensor data from a sensor connected to a UMTS<E EVBs J804 i2c pins. All i get back is a empty array. Any idea on what the problem could be? We are using the bg95-m3 module.
QuecPython code can be found in the link below. main.py (1.8 KB)
I have downloaded the latest version (V001) from the download zone, when I run modem.getDevFwVersion() I get following response
BG95M3LAR02A03_BETA1204_31.200.31.200_BETA1204
I made basically those changes earlier. Turned out that the main issue I had left was on the hardware side, now that I moved the sensor and resistors to a breadboard everything is working as it should.
