I’m working on the EC25 Mini PCIe module and I’m trying to read GPS data from the available UART port. I’m using the following python script:
portwrite = "/dev/ttyUSB3"
print("Connecting Port..")
try:
ser = serial.Serial(portwrite, baudrate = 115200, timeout = 1,rtscts=True, dsrdtr=True)
ser.write('AT+QGPSCFG="outport,uartdebug"\r'.encode())
sleep(1)
ser.write('AT+QGPS=1\r'.encode())
ser.close()
sleep(1)
except Exception as e:
print("Serial port connection failed.")
print(e)
where I configure the outport as UART. However, I don’t read any data in UART. I do read if I run the second following script in python:
ser = serial.Serial(port, baudrate = 115200, timeout = 0.5,rtscts=True, dsrdtr=True)
while True:
data = ser.readline().decode('utf-8')
print(data)
sleep(2)
Not sure if I’m doing this correctly and so I would like to someone can help me with this.
Thanks!
