We have expirenced some random freezes of the BG95-M3. It happens maybe 1/20 times, but when it freezes the only way is to power cycle it to return to operational state. When we deploy our solution in the field this will completly break our module. When the freeze happens, nothing in the module is responding, At commands sent to the bg95 will not get any answear and not even commands sent from Qnavigator will get any responses . Is this a known issue?
I am sure we give it enough voltage, (we give it a steady 3.8 V).
FIrmware Version: BG95M3LAR02A03
Ran QwinLog and I got the following log when the bg95 crashed.
2024-03-05 14:45:50.713 ---------------- LogCache Size: 257 KB
2024-03-05 14:45:50.713 ---------------- QXDM Read Data To File, log type: 1, Size: 8025
2024-03-05 14:45:50.913 ---------------- LogCache Size: 265 KB
2024-03-05 14:45:50.913 ---------------- QXDM Read Data To File, log type: 1, Size: 7038
2024-03-05 14:45:51.353 ---------------- LogCache Size: 272 KB
2024-03-05 14:45:51.354 ---------------- QXDM Read Data To File, log type: 1, Size: 7916
2024-03-05 14:45:51.552 ---------------- LogCache Size: 280 KB
2024-03-05 14:45:51.552 ---------------- QXDM Read Data To File, log type: 1, Size: 7766
2024-03-05 14:45:51.571 check SerialAutoReconnectThread
2024-03-05 14:45:51.572 Stop cmd size = 5
2024-03-05 14:45:51.572 stop cmd index = 0 sending
2024-03-05 14:45:51.572 stop cmd index = 1 sending
2024-03-05 14:45:51.573 stop cmd index = 2 sending
2024-03-05 14:45:51.573 stop cmd index = 3 sending
2024-03-05 14:45:51.574 stop cmd index = 4 sending
2024-03-05 14:45:51.574 Try to disable qtrace. times = 1
2024-03-05 14:45:51.596 SerialReadAllData 6 bytes
2024-03-05 14:45:51.596 Try to disable qtrace. times = 2
2024-03-05 14:45:51.606 SerialReadAllData 15 bytes
2024-03-05 14:45:51.607 Try to disable qtrace. times = 3
2024-03-05 14:45:51.607 SerialReadAllData 12 bytes
2024-03-05 14:45:51.607 Try to disable qtrace. times = 4
2024-03-05 14:45:51.608 SerialReadAllData 8 bytes
2024-03-05 14:45:51.608 Try to disable qtrace. times = 5
2024-03-05 14:45:51.609 SerialReadAllData 20 bytes
2024-03-05 14:45:51.609 Try to disable qtrace. times = 6
2024-03-05 14:45:51.610 SerialReadAllData 20 bytes
2024-03-05 14:45:51.610 Try to disable qtrace. times = 7
2024-03-05 14:45:51.611 SerialReadAllData 20 bytes
2024-03-05 14:45:51.611 Try to disable qtrace. times = 8
2024-03-05 14:45:51.611 Try to disable qtrace. times = 9
2024-03-05 14:45:51.613 SerialReadAllData 20 bytes
2024-03-05 14:45:51.613 Try to disable qtrace. times = 10
2024-03-05 14:45:51.614 SerialReadAllData 20 bytes
2024-03-05 14:45:51.614 Try to disable qtrace. times = 11
2024-03-05 14:45:51.616 SerialReadAllData 20 bytes
2024-03-05 14:45:51.617 Try to disable qtrace. times = 12
2024-03-05 14:45:51.619 SerialReadAllData 20 bytes
2024-03-05 14:45:51.619 Try to disable qtrace. times = 13
2024-03-05 14:45:51.620 SerialReadAllData 20 bytes
2024-03-05 14:45:51.620 Try to disable qtrace. times = 14
