Questions regarding Quectel RG500U-EB
Hi everyone. I have a router Cudy P2 5G. This router has a RG500U-EB module. I have working OpenWRT image for this router. My question is, what kind of modes does this module supports ? The AT+QCFG”usbnet” command shows 1,3,5,11,13,15, if i remember correctly, but i can’t get it to switch to other mode. Regardless of settings it uses rndis-host driver. How can i change it to other mode, and if it’s even possible ? Thank you for answer.
I have reasons to believe that there are not so many differences between RG500U and RM500U. See this and the following my posts:
Ok, but why i can’t make it switch to ecm or ncm mode ? It’s in rndis regardless of usbnet setting ?
Show the result of the following command: cat /sys/kernel/debug/usb/devices
Right now, router is back on original Cudy firmware, but that’s how it showed up when i flashed OpenWRT:
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  4 Spd=480  MxCh= 0
D:  Ver= 2.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=2c7c ProdID=0900 Rev= 4.04
S:  Manufacturer=Quectel
S:  Product=RG500U-EB
S:  SerialNumber=0123456789ABCDEF
C:* #Ifs= 7 Cfg#= 1 Atr=c0 MxPwr=500mA
A:  FirstIf#= 0 IfCount= 2 Cls=e0(wlcon) Sub=01 Prot=03
I:* If#= 0 Alt= 0 #EPs= 1 Cls=e0(wlcon) Sub=01 Prot=03 Driver=rndis_host
E:  Ad=82(I) Atr=03(Int.) MxPS=   8 Ivl=32ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=rndis_host
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
There is a possibility that the modem runs customized firmware that prevents switching to other USB modes.
I would start from re-flashing.
Dear @LS3480
It shows as RG500UEBAAR03A08M4G_01
Hi, i’d like to ask is there a newer firmware for this modem. My cuurnet firmware version is RG500UEBAAR03A08M4G_01.300.01.300. Thank you for answer.
Dear @LS3480
Good everning Silvia i am looking latest firmware for my module and the current version it shows RG500UEBAAR03A01M4G .
Helo can anybody answer me ?
Dear @Inayat_Rehman
Hi Silvia I have the same router with firm AT+CGMR
Is there anything newer? Any help would be much appreciated
Hello Aleesi,
Please check your mail!
Best Regards!
