Questions about AT+COPS=4 with BG95-M3/5
we are trying to reduce the time for Network registration in eMTC, NBIoT and GPRS, and AT+COPS=4 seems a great idea, however we need some info on the module behaviour
Let’s say I have set eMTC->NBIoT->GPRS sequence with ‘nwscanmode’, ‘iotopmode’ and ‘servicemode’, and I send the command AT+COPS=4,2,“12345”,9 (= try first to connect to NBIoT with PLMN “12345”, if fail switch to auto):
If the modem fail to connect to NBIoT with PLMN "12345, will it then try to connect to eMTC & GPRS only with selected PLMN “12345” OR will it search for any PLMN with the order eMTC->NBIoT->GPRS ( similar to AT+COPS=0 command) ?
In other words, is the command AT+COPS=4,“12345”,9 similar to
AT+COPS=1,2,“12345”,9
if fail AT+COPS=1,2,“12345”,8
if fail AT+COPS=1,2,“12345”,9
if fail AT+COPS=1,2,“12345”,0
or similar to
if fail AT+COPS=0
or something else ?
Yes, I think your understanding is correct
Excuse me Herbert, can you be more clear ? Which of the two options apply :
A) If the modem fail to connect to NBIoT with PLMN "12345, it will then try to connect to eMTC & GPRS only with selected PLMN “12345”
OR
B) If the modem fail to connect to NBIoT with PLMN "12345, it will search for any PLMN with the order eMTC->NBIoT->GPRS
Which of the two options is valid ?
A is correct discription
