Hello, I’m using TD210: IoT Cellular Modem and I want obtain the RTC using AT commands.
If I use the next command, the return response is wrong.
AT+CCLK?
+CCLK: “80/01/06,00:00:00-24”
But if I use first the command:
AT+CTZU=1
AT+CCLK?
+CCLK: “24/06/05,13:20:00-24”
The date and time are updated, but the update corresponds to GMT.
I saw in other responses that using the command as follows AT+CTZU=3 allows you to enable automatic time zone update via NITZ and update LOCAL time to RTC, but the uc20 Quectel series doesn’t let you set the command AT+CTZU with a 3.
How can I resolve it?
