I am using Open5GS as core network and Quectel modem connected to a Raspberry Pi 4 as UE.
I have an edge Raspberry Pi 5 with a docker container that has the edge UPF service inside. This UPF service has an interface called ogstun:
ogstun: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 10.0.101.1 netmask 255.255.255.0 destination 10.0.101.1
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 500 (UNSPEC)
RX packets 303555 bytes 150399928 (150.3 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 220176 bytes 40154639 (40.1 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
This interface communicates with the modem, which has the ip 10.0.101.0/24 (changes with each connection).
When I send information from the UPF interface to the modem, the modem seems to not receive the information because I do tcpdums on the LAN interface inside the UE Raspberry Pi, and it does not receive anything. The ports opened by the modem seem to be the following, using nmap from the console on the upf container:
root@f950008576d4:/open5gs# nmap -p 1-65535 10.0.101.2
Starting Nmap 7.80 ( https://nmap.org ) at 2024-04-30 16:42 CEST
Nmap scan report for 10.0.101.2
Host is up (0.073s latency).
Not shown: 65532 closed ports
PORT STATE SERVICE
80/tcp filtered http
443/tcp filtered https
1555/tcp open livelan
Nmap done: 1 IP address (1 host up) scanned in 18.97 seconds
I do not know what is happening exactly, but I think that the problem is the data sent is blocked because the ports are not opened externally. How can I do port forwarding on the modem? How can I open ports on the modem?
