Quectel RM520N-GL to connect Telus 5G
I am using waveshare dongle with quectel RM520N-GL to connect to Telus 5G, but failed. Any way that I can use to address where the issue is? Thanks
Dear @Joey1
What do you mean of “failed”? Can’t register 5G or others? Is it possible to connect with other network?
Hi, it works now with the modification of the connection mode.
But in Ubuntu 24.04, whenever I tried to open a website. The bar of signal strength will disappear on top right corner of the screen and will be back if I close the browser.
Sometimes it won’t disappear, but it will after replug the dongle.
Dear @Joey1
For the bar, I am not sure what happened.
Do you check the signal of module via AT command? or check the status of module when disappear.
