Quectel RM520N-GL module isn't working with Banana Pi BPI-R4
Hi everyone,
I’m having trouble getting my Quectel RM520N-GL module (RM520NGLAP-M20-SGASA) to work with my Banana Pi BPI-R4. I’ve tried various OpenWRT versions without success,
Can anyone give some advice on how to get this module working?
root@OpenWrt:~# uname -a
Linux OpenWrt 6.6.58 #0 SMP Sat Oct 26 14:21:03 2024 aarch64 GNU/Linux
root@OpenWrt:~# lspci
0000:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0000:01:00.0 Network controller: MEDIATEK Corp. Device 7990
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0001:01:00.0 Network controller: MEDIATEK Corp. Device 7991
0002:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0002:01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980 (DRAM-less)
0003:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0003:01:00.0 Unassigned class [ff00]: Qualcomm Technologies, Inc Device 0308
root@OpenWrt:~# lspci -v
0000:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 119
        Memory at 30500000 (64-bit, non-prefetchable) [size=32K]
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: [disabled] [32-bit]
        Memory behind bridge: 30400000-304fffff [size=1M] [32-bit]
        Prefetchable memory behind bridge: 30200000-303fffff [size=2M] [32-bit]
        Capabilities: [80] Express Root Port (Slot-), IntMsgNum 0
        Capabilities: [e0] MSI: Enable+ Count=1/32 Maskable+ 64bit+
        Capabilities: [f8] Power Management version 3
        Capabilities: [100] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
        Capabilities: [110] L1 PM Substates
        Capabilities: [200] Advanced Error Reporting
        Capabilities: [300] Secondary PCI Express
        Kernel driver in use: pcieport
lspci: Unable to load libkmod resources: error -2
        Subsystem: MEDIATEK Corp. Device 6639
        Flags: bus master, fast devsel, latency 0, IRQ 133
        Memory at 30200000 (64-bit, prefetchable) [size=2M]
        Memory at 30400000 (64-bit, non-prefetchable) [size=32K]
        Capabilities: [80] Express Endpoint, IntMsgNum 0
        Capabilities: [108] Latency Tolerance Reporting
        Kernel driver in use: mt7996e
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 122
        Memory at 38500000 (64-bit, non-prefetchable) [size=32K]
        Memory behind bridge: 38400000-384fffff [size=1M] [32-bit]
        Prefetchable memory behind bridge: 38200000-383fffff [size=2M] [32-bit]
        Flags: bus master, fast devsel, latency 0, IRQ 134
        Memory at 38200000 (64-bit, prefetchable) [size=2M]
        Memory at 38400000 (64-bit, non-prefetchable) [size=32K]
        Kernel driver in use: mt7996e_hif
0002:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 116
        Memory at 28300000 (64-bit, non-prefetchable) [size=32K]
        Memory behind bridge: 28200000-282fffff [size=1M] [32-bit]
        Prefetchable memory behind bridge: [disabled] [64-bit]
0002:01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980 (DRAM-less) (prog-if 02 [NVM Express])
        Subsystem: Samsung Electronics Co Ltd Device a801
        Flags: fast devsel, IRQ 255
        Memory at 28200000 (64-bit, non-prefetchable) [disabled] [size=16K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
        Capabilities: [70] Express Endpoint, IntMsgNum 0
        Capabilities: [b0] MSI-X: Enable- Count=13 Masked-
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [148] Device Serial Number 00-00-00-00-00-00-00-00
        Capabilities: [158] Power Budgeting <?>
        Capabilities: [168] Secondary PCI Express
        Capabilities: [188] Latency Tolerance Reporting
        Capabilities: [190] L1 PM Substates
0003:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 113
        Memory at 20300000 (64-bit, non-prefetchable) [size=32K]
        Memory behind bridge: 20200000-202fffff [size=1M] [32-bit]
        Subsystem: Qualcomm Technologies, Inc Device 0308
        Flags: fast devsel
        Memory at 20200000 (64-bit, non-prefetchable) [disabled] [size=4K]
        Memory at 20201000 (64-bit, non-prefetchable) [disabled] [size=4K]
        Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
        Capabilities: [148] Secondary PCI Express
        Capabilities: [168] Physical Layer 16.0 GT/s <?>
        Capabilities: [18c] Lane Margining at the Receiver
        Capabilities: [19c] Transaction Processing Hints
        Capabilities: [228] Latency Tolerance Reporting
        Capabilities: [230] L1 PM Substates
        Capabilities: [240] Data Link Feature <?>
root@OpenWrt:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux 6.6.58 xhci-hcd xHCI Host Controller
Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc.          USB2.0 Hub
Bus 001 Device 003: ID 2109:8822 VIA Labs, Inc.          USB Billboard Device
Bus 002 Device 001: ID 1d6b:0003 Linux 6.6.58 xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc.          USB3.1 Hub
Just from this log, it seems that the PCIE device is recognized.
Have you installed the Quectel PCIE driver pcie_mhi? Can you show the dmesg log.
In additional, please make sure the BPI-R4 support PCIE MSI. If not, it does not support the Quectel module. As I know, for MT7621, it is not supported.
Dear Bean,
I apologize for the delay.
I haven’t installed the Quectel PCIE driver, pcie_mhi. Could you please direct me to the driver webpage so I can install it?
Thank you for your support. I am not proficient in Linux, so I would appreciate it if you could guide me towards a solution
bpi-r4 dmesg.txt (60.8 KB)
Please check the pcie_mhi.
You can put the pcie_mhi anywhere as you like and just make sure that the pcie_mhi is loaded.
