I am using a Quectel RM502Q modem for 5G applications. I was just wondering if it is possible to have both both HTTP and MQTT AT commands in the RM502.
According to the results of the query, RM502Q only supports HTTP
Hello Herbert,
Thanks for confirming. I am in search for a 5G modem for one of our specific applications, that has supports both MQTT and HTTP AT commands, preferably with an UART interface. Which model would you recommend?
You can choose the RG500Q
Thanks Herbert,
Does the RG500U also fall under the RG500Q family? I see from Quectel product portfolio that the RG500U comes with a M.2 form factor (RG500U-EA M.2). Does the RG500U-EA M.2 also have MQTT, HTTP AT command support as well as UART?
The RG500U does not support MQTT
Hello Herbert,
Would you please share the AT command document for MQTT for the RG500Q?We got ourselves a RG500Q and referring to the GSM_MQTT_Application_Note_V1.2 we tried the AT command, AT+QMTCFG=? which returned an error.
Perhaps your current firmware version is not supported, please provide your current version, or upgrade to the latest firmware version and try again
my current version is RG500QEAAAR11A05M4G
I have sent the latest firmware to you,you try again,and I hope you can click the
for me,thanks
Thanks Herbert. I received it.
