I sure did. 0-3. Interface changes but no data.
You should ask explicitly the latest
drivers and firmware for the module although it is eng. sample.
Out of curiosity (AT+QCFG="usbnet",5)NCM; the latest NDIS driver Version: 2.7 , in the guide 2.4, does not include x72 and x75…
Hello Bean, the command you provided solved the problem, thanks a lot !
I have a question for you guys, my mobile operator drop the connection every 4 hours so I need to handle the reconnection, can quectel modules do that automatically ? My RM502Q is installed on a openwrt based board and right now I check if the module is online with: uqmi -d /dev/cdc-wdm0 --get-data-status and if the result of this command is offline I bring the interface down, and send via AT command AT+CFUN=0, AT+CFUN=1. Once the modem is back online I bring the interface up again in openwrt. Is this a correct way to handle re-connection ? Is there a better/faster way to do it ? Thanks a lot to evryone
Unrelated to the topic. Ask your question on OpenWrt forum if you can’t find the answer there using search.
