Quectel RM500U-EA Vodafone New Zealand No Service
Hi Forum!
Hardware:
Quectel RM500U-EA
(in a ZBTlink ZBT-Z8105AX)
Problem:
After Reboot sometimes a Cell Tower and a Signal% are reported but ‘No Service’.
Then No Service and No Cell tower and No Signal either permanently.
And I never get an Internet connection.
Parameters:
Provider: Vodafone
The SIM card is taken from my old 4G modem/router and is working (verified back and forth).
Service available:
  • 4G - 700MHz (Band 28)
  • 4G - 1800MHz (Band 3)
  • 4G - 2100MHz (Band 1)
  • 4G - 2600MHz (Band 7)
  • 5G Band N7 (NR 2600MHz)
  • 5G Band 78 (NR 3500MHz)-NSA
Diagnostic is hard because of the constant interference of the active shell scripts.
ATI
RM500U-EA
Revision: RM500UEAAAR03A13M2G
AT+QICSGP=1
+QICSGP: 1,“vodafone”,“”,“”,0
AT+QNWPREFCFG=“mode_pref”
+QNWPREFCFG: “mode_pref”,LTE
AT+QNWPREFCFG=“gw_band”
+QNWPREFCFG: “gw_band”,2
AT+QNWPREFCFG=“lte_band”
+QNWPREFCFG: “lte_band”,1:3:7:28
AT+QNWPREFCFG=“nr5g_band”
+QNWPREFCFG: “nr5g_band”,77:78
AT+QCFG=“CLAT”
+QCFG: “clat”,0
AT+QCFG=“nat”
+QCFG: “nat”,0
+CPIN: READY
Result of Reset Bands, Network Search Auto:
Module Quectel RM500U-EA
IMEI xxx
ICCID xxx
APN vodafone
PIN READY
NetSearch mode AUTO
BAND 3G: 1:2:5:8
4G: 1:2:3:4:5:7:8:20:28:40:41:66
5G: 1:3:5:7:8:20:28:66:38:40:41:77:78
Current Freq Band +QNWINFO: No Service
Cell Info Cell Physical ID: 95
ISP No Service
Signal 72%
Question: I need a reliable way to diagnose the module.
I can’t find anything in the FAQs besides
Debug level output with
AT+QCFG=“dbgctl”,0
which seems to be ignored/has no effect?
Also a more recent firmware may help?
Thanks in Advance.
Dear @NZ_user
The module is in ZBT, we don’t know the logic in it.
Please contact ZBT manufacture to support.
Dear @silvia
So let ME worry about the OpenWRT side of the router. Please answer the following two questions:
Is there a newer firmware version for the
RM500U-EA
PLEASE stop ignoring my requests and send it to me together with the instructions/tools to apply it!
And PLEASE give me the AT commands to connect to VODAFONE NEW ZEALAND at
Start with
AT “&F”
Dear @NZ_user
We have the version of RM500U, but your device is ZBT, we don’t know how to upgrade in it.
Dear @silvia
If you tell me about it I can help you.
It is basically a Linux shell environment. So if you have a flash tool for that? I can only guess because you don’t give any information…
Dear @NZ_user
I can share the tool and firmware version.
But I don’t know if there is any limitations and risk on your device. Do you accept any unexpected risk?
If yes, I will share to you.
Dear @silvia
Yes I accept the risk. Thank you for helping me.
Dear @NZ_user
Dear @silvia
Thank you for the firmware.
Although I have trouble to determine if the version supplied is really newer than the one installed:
The document RM500U-EA-AA_Firmware_Release_Notes_V0313_01.302.01.302 claims to contain
Firmware RM500UEAAAR03A13M2G 01.302.01.302
The modem says it already has Quectel RM500U-EA
The update version file says
[udx710_module+initgc+console+sec-user-native_FDDNRSEC_21A]
PAC_Time=2026-03-10-Tue:15:38
AP=udx710-module+unisoc-initgc-1.0+W26.11.2:15.03.32+user+native
CP0=5G_MODEM_21A_W23.38.3_P36|udx710_modem|02-04-2026 18:49:35
CP2=
firmware=
gnss_version=
Product=udx710_module+initgc+console+sec
gms_version=
All of that is not helpful or indicates to be the SAME version as installed.
Am I correct?
Also I am still waiting for the initialisation sequence of AT commmands I requested.
Regards from New Zealand
Dear @NZ_user
Please share the response of AT comands as below, they can check whether it registered in newtork.
AT+COPS?
AT+QENG=“servingcell”
Dear @silvia
AT+COPS?
+COPS: 0
+QENG: “servingcell”,“SEARCH”
Dear @NZ_user
From the log, it is searching network.
Do you confirm the SIM card work with other device? Or change other SIM?
Is it correct APN? Currently, it is vodafone.
If still fail, it is better to contact ZBT.
Dear @silvia
I confirm it is the same SIM card which still works in my other device over which I am talking to you now.
That is a bit confusing because my provider uses the network of Vodafone.
I contactedd my provider and the APN used ‘@ws.wn.fwa’ is the correct one.
I assume that is getting translated to Vodafone in communication with the cell tower?
I really have trouble understanding what makes it so horribly complicated for you to give me the correct initialisation sequence for this communication!
Either you have a database for the various countries with the corrrect sequences for the providers.
Or you have a standard procedure to construct the sequence from the parameters given.
If you need more parameters tell me.
Either way it shouldn’t be SO HARD to hand out these AT command sequence?!?!?
Daer @NZ_user
Please try AT commands below:
AT+CFUN=0
At+QICSGP=1,3,“correct APN”
AT+CFUN=1
AT+CFUN=0
+CPIN: NOT READY
+QUSIM: 1
+CPIN: READY
+QIND: PB DONE
+QIND: SMS DONE
AT+QICSGP=1,3,“@ws.wn.fwa”
AT+CFUN=1
AT+CSQ
+CSQ: 99,99
AT+QREJINFO?
+QREJINFO: 00000,2,0,6,0,0,“0000”,“0”,“0000000000000000”
AT+COPS?
+COPS: 0
AT+CREG?
+CREG: 0,0
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“@ws.wn.fwa”,“0.0.0.0”,0,0,0,0,0,0,0,0,0,0
Dear @NZ_user
Do you have USB ports? Is it possible to capture log?
From AT log, after execute AT+CFUN=0, CPE set CFUN to 1. There have any logic of your CPE.
Dear @silvia
If I understand you correctly the sequence in the red rectangle shoudln’t have happened?
And the sequence inidicates an AT+CFUN=1 got send from another source (‘CPE’=router)?
Please confirm I understood you correctly before I dive into the command structure of the scripts on the router.
Regards
Dear @NZ_user
Yes, in red rectangle, it means SIM is ready, like CFUN=1.
In CFUN:0, it means Minimum function mode, SIM card not ready.
So I suspect router has logic to enable CFUN:1 .
It is recommended to contact manufacture of your router.
