Hi Guys,
Can someone please provide the CA_ENDC document for RG620T-EU Module.
Appreciate quick response.
Hi Guys,
Hello everyone,
I am currently working with an RG620T-EU modem and am looking for a way to retrieve the CA_ENDC information.
Has anyone successfully retrieved this information using AT commands or via USB communication? If so, could you please share the command or method?
Any help or insights would be greatly appreciated!
Thanks in advance.
Dear @Abhijeet_Mohanty @Hamad
Sorry about this, I can’t share ENDC document directly.
Please share which band you want to know, I will share part of them to you.
Or you can contact with your provider and ask them to share .
we have problem with RG620T-EU support 300mhz but not aggregation 2 5G BAND ( N77+N78) way?
i see in another router support 300mhz has aggregation 2 5G BAND ( N77+N78)
is there aproblem with the module RG620T-EU?
or problem with software router ?
Dear @MOHAMMED_m_ALZAHRANI
RG620T-EU supports n77+n78, the max bandwidth is 100MHz.
I meen can i aggregation N77+N78 NSA together ?
Because i try aggregation N77+N78+B3 -----N77+N78+B1 Useless
Just N77+B3 or N78+B1
Dos the module support 300mhz?
It supports n77+n78, but doesn’t support N77+N78+B3 -----N77+N78+B1.
The maximun is 100Mhz, not 300Mhz.
hello ,
I’m using same modem and I need to know if it support
n77+n77+B1
n77+n77+B3
what is the max bandwidth? and if not 300mhz which 5g combination that support 300mhz bandwidth?
with greetings
Dear @No_WaY
I have shared the information to you, please check in another topic.
does this module support n28+n78?
Dear @faisal89
