I went through the datasheet of Quectel RG255C-GL and it lists eSIM as Optional. I have 2 physical units and I don’t really know how to tell if my units support eSIM. What should I look for to check if eSIM is available?
And another question: do you have an application note showing how to use the eSIM? Maybe for a different module but that would work for RG255C-GL as well?
Thank you for your reply. The unit I have says: RG255CGL00AB-4M2-SGASA.
If there are any AT commands to check that the eSIM is supported I could also do that. I am able to send AT commands to the module.
Regarding the eSIM official document: is there a plan to share such information in the near future (maybe by the end of the year)?
