Quectel PI H1 - Display Interfaces MIPI DSI vs HDMI vs DisplayPort
Quectel Pi H1 provides multiple display output options to accommodate different application scenarios, ranging from embedded touch panels to external monitors and digital signage systems.
The platform supports three primary display interfaces:
  • MIPI DSI
  • HDMI
  • USB Type-C DisplayPort (DP Alt Mode)
Each interface has its own advantages and intended use cases. This article provides an overview of the supported display interfaces and helps developers determine which interface best fits their application requirements.
Display Interface Comparison
Feature MIPI DSI HDMI DisplayPort (Type-C)
Interface Type Embedded Display External Display External Display
Connector MIPI Connector Micro HDMI USB Type-C
Typical Use Case LCD Panels Monitors / TVs Monitors / Docking Stations
Touch Support Yes (Panel Dependent) External USB Required External USB Required
Cable Length Short Long Long
Embedded Product Friendly Excellent Moderate Moderate
Development Convenience Moderate Excellent Excellent
Industrial HMI Applications Excellent Good Good
MIPI DSI Display
What is MIPI DSI?
MIPI DSI (Mobile Industry Processor Interface Display Serial Interface) is a display interface commonly used in smartphones, tablets, embedded systems, and industrial touch panels.
Unlike HDMI or DisplayPort, MIPI DSI is designed specifically for direct connection to LCD modules and is commonly used in embedded products where a compact display solution is required.
Advantages of MIPI DSI
Compact Design
MIPI displays connect directly to the board without requiring bulky external display connectors.
This makes them ideal for:
  • Human Machine Interface (HMI) applications
  • Embedded control panels
  • Smart displays
  • Kiosks
  • Industrial terminals
Integrated Touch Panels
Many MIPI LCD modules include integrated capacitive touch functionality, simplifying system integration.
Lower Power Consumption
Compared to external monitors, MIPI panels typically consume less power and are better suited for battery-powered or embedded applications.
Important Precautions
:warning: Always disconnect power before connecting or disconnecting a MIPI display.
Before installing, removing, or replacing a MIPI display module:
  1. Power off the Quectel Pi H1.
  2. Disconnect the power supply.
  3. Connect or disconnect the MIPI display cable.
  4. Verify the cable orientation and locking mechanism.
  5. Reconnect power and boot the system.
Hot-plugging a MIPI display while the board is powered on is not recommended and may result in:
  • Display detection failures
  • Unstable display operation
  • Potential hardware damage to the display interface
MIPI DSI Configuration
After physically connecting the display, additional software configuration may be required depending on the display panel being used.
Refer to the official MIPI display guide:
https://developer.quectel.com/doc/sbc/Quectel-Pi-H1/en/User-Guide/Peripheral-Guide/Mipi.html
The guide includes:
  • Supported MIPI display modules
  • Hardware connection diagrams
  • Device Tree configuration
  • Display enablement procedures
  • Verification methods
Recommended Use Cases
Choose MIPI DSI when developing:
  • Industrial control panels
  • Smart home displays
  • Embedded HMI systems
  • Portable devices
  • Custom LCD products
HDMI Display
What is HDMI?
HDMI (High-Definition Multimedia Interface) is one of the most widely used display interfaces for connecting monitors and televisions.
Quectel Pi H1 provides a Micro HDMI connector that can be connected directly to standard HDMI displays using a suitable cable or adapter.
Advantages of HDMI
Plug-and-Play Development
Most developers already have access to HDMI monitors, making it the easiest display interface for development and evaluation.
Broad Compatibility
HDMI works with:
  • Computer monitors
  • TVs
  • Projectors
  • Industrial displays
without requiring special display drivers.
Simple Setup
Simply connect the display and power on the board.
For most monitors, display configuration is automatically detected.
HDMI Configuration
For detailed HDMI setup instructions, refer to the official HDMI guide:
https://developer.quectel.com/doc/sbc/Quectel-Pi-H1/en/User-Guide/Peripheral-Guide/HDMI.html
The guide covers:
  • HDMI display connection
  • Display verification
  • Resolution configuration
  • Troubleshooting procedures
Choose HDMI when:
  • Evaluating Quectel Pi H1
  • Developing software applications
  • Performing hardware validation
  • Running demonstrations
  • Connecting to TVs or projectors
What is DisplayPort over USB Type-C?
Quectel Pi H1 supports DisplayPort Alternate Mode through its USB Type-C interface.
This allows video output through a USB Type-C connection without requiring a dedicated HDMI cable.
Advantages of DisplayPort
Modern Display Connectivity
Many modern monitors support USB Type-C display input directly.
This allows:
  • Video transmission
  • Simplified cabling
  • Docking station integration
through a single interface.
Professional Workstation Support
DisplayPort is commonly used in:
  • High-resolution monitors
  • Engineering workstations
  • AI development environments
  • Digital signage applications
Docking Station Compatibility
USB Type-C docking stations can provide:
  • Display output
  • USB expansion
  • Ethernet connectivity
through a single connection.
DisplayPort Configuration
For detailed DisplayPort setup instructions, refer to the official DP guide:
https://developer.quectel.com/doc/sbc/Quectel-Pi-H1/en/User-Guide/Peripheral-Guide/DP.html
The guide covers:
  • DP Alt Mode support
  • USB Type-C display connection
  • Supported display scenarios
Choose DisplayPort when:
  • Using modern USB Type-C monitors
  • Connecting through docking stations
  • Building digital signage solutions
  • Creating workstation-style development environments
Which Display Interface Should You Choose?
Choose MIPI DSI If
✓ You are developing a custom product
✓ You need an integrated touch display
✓ Space constraints are important
✓ The display will be permanently integrated into the device
Examples:
  • Smart control panels
  • Industrial HMIs
  • Medical devices
  • Embedded kiosks
Choose HDMI If
✓ You are performing software development
✓ You need quick setup
✓ You are using standard monitors
✓ You want the simplest development experience
Examples:
  • Application development
  • AI evaluation
  • Demonstrations
  • Hardware validation
Choose DisplayPort If
✓ You use USB Type-C monitors
✓ You require docking station support
✓ You need a modern desktop setup
✓ You are building commercial display solutions
Examples:
  • Digital signage
  • Smart displays
  • Professional development environments
Development Recommendation
For first-time Quectel Pi H1 users, HDMI is generally the easiest display interface to begin with because of its widespread compatibility and plug-and-play experience.
Once the application requirements are defined, developers can evaluate whether MIPI DSI or DisplayPort is more suitable for their final product design.
In summary:
  • MIPI DSI – Best for embedded products and touch displays.
  • HDMI – Best for development and general-purpose use.
  • DisplayPort (Type-C) – Best for modern monitors and professional display environments.
Selecting the appropriate display interface early in the design process can simplify development and improve the overall user experience of the final product.
References
