Quectel Module IMEI Problem
In some countries, it is only legal to use “Modem” IMEI on cellular network. However, the Quectel EG25-G module is known to use “Phone” IMEI numbers by default, which can cause registration problems and potentially violate local regulations.
It is important to ensure that any device utilizing the Quectel EG25-G module in some country has a valid and properly configured “modem” IMEI number.
Using a device with an incorrect or invalid IMEI format can result in potential legal issues. Therefore, it is crucial to take the necessary steps to ensure that the Quectel EG25-G module is correctly configured to comply with local regulations and avoid any potential problems.
for example check this IMEI in www.imei.info imei: 865326060135608
