Hi Kyson,
yes, the modem internal address is pingable from the module itself…
root@imx8mm-var-dart:~# ifconfig
usb0 Link encap:Ethernet HWaddr 86:e2:d3:9e:9a:3f
inet addr:192.168.225.21 Bcast:192.168.225.255 Mask:255.255.255.0
inet6 addr: fe80::466e:b05e:8a99:ee41/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:66 errors:0 dropped:0 overruns:0 frame:0
TX packets:106 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:6289 (6.1 KiB) TX bytes:14571 (14.2 KiB)
root@imx8mm-var-dart:~# ping 192.168.225.21
PING 192.168.225.21 (192.168.225.21) 56(84) bytes of data.
64 bytes from 192.168.225.21: icmp_seq=1 ttl=64 time=0.109 ms
64 bytes from 192.168.225.21: icmp_seq=2 ttl=64 time=0.101 ms
64 bytes from 192.168.225.21: icmp_seq=3 ttl=64 time=0.100 ms
I tested also to ping the modem gateway ( 192.168.225.1 )…
(from “nmcli con show usb0”…)
IP4.ADDRESS[1]: 192.168.225.21/24
IP4.GATEWAY: 192.168.225.1
IP4.ROUTE[1]: dst = 0.0.0.0/0, nh = 192.168.225.1, mt = 102
IP4.ROUTE[2]: dst = 192.168.225.0/24, nh = 0.0.0.0, mt = 102
IP4.DNS[1]: 192.168.225.1
and it works…
root@imx8mm-var-dart:~# ping 192.168.225.1
PING 192.168.225.1 (192.168.225.1) 56(84) bytes of data.
64 bytes from 192.168.225.1: icmp_seq=1 ttl=64 time=1.42 ms
64 bytes from 192.168.225.1: icmp_seq=2 ttl=64 time=1.32 ms
Also if I test (from the module) a traceroute command, works…
root@imx8mm-var-dart:~# traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 46 byte packets
1 192.168.225.1 (192.168.225.1) 1.290 ms 1.396 ms 1.993 ms
2 91.81.223.245 (91.81.223.245) 246.073 ms 98.861 ms 181.004 ms
3 10.133.42.29 (10.133.42.29) 28.966 ms 45.566 ms 23.833 ms
4 10.128.94.14 (10.128.94.14) 25.642 ms 69.330 ms 25.110 ms
5 10.128.94.236 (10.128.94.236) 25.718 ms 31.681 ms 25.556 ms
6 10.128.94.1 (10.128.94.1) 34.150 ms 32.534 ms 24.805 ms
7 83.224.40.185 (83.224.40.185) 25.587 ms 33.143 ms 22.956 ms
8 185.210.48.1 (185.210.48.1) 25.726 ms 79.003 ms 25.232 ms
9 * * *
10 dns.google (8.8.8.8) 26.093 ms 172.253.79.33 (172.253.79.33) 26.264 ms 216.239.49.181 (216.239.49.181) 49.392 ms
however seems not passing from the public address (in this case 91.xx.xx.11)
Update: yesterday I tested the EC25 modem (mounted on the evk) using a linux PC (lubuntu) and the result is the same…the public address is reachable , the ports are all closed.
Thanks, have a nice day.
BR
mc
