i have tracking gps unit ,trying to connect it through roaming,it connect 2 minutes and then disconnect,any idea plz why
I’m sorry to reply you so late.
Could you describe your specific problem and the specific steps?
thank you ,ihave quectel modem mc60 ,when connect it connect roaming,it connects just 2 miniutes and the modem restart.
could you advise
I want to confirm with you the following points:
1.Is this happening every time when you turn the module on?
2.Will this happen if the module is not inserted into the SIM card?
If the SIM card is not inserted this phenomenon not occured,it may be power supply issue.If you are using a custom PCB, you may have to increase the capacitance values, if you are using an evaluation board, you may use a higher current capability supply.
i have another gps tracker (ublox)its working fine.
I will communicate with you via email later, please check the email.
hi im waiting plz your assistance
Please confirm if you have received the email.I have sent the email to you on January 25th.
Or you can provide me with another email address.
Hello
I’m also facing a same issue that my device MC60 is unable operate in Roaming area. kindly suggest me the solution for it.
Hi Tech_Sunyash:
I’m facing a GNSS network problem my device gets GPS network loss rapidly when i’m travelling. so can you please help me with gain calculation on antenna.
