Dear Team,
We are using quectel MC60 model firmware version
Quectel_Ltd
Quectel_MC60
Revision: MC60CAR01A13
Can you please guide me how solve this kind of issue
hi, Pronay97:
Please refer to the instruction manual below:
Quectel_MC60&MC90_AT_Commands_Manual_V1.3.pdf (1.6 MB) Quectel_MC60_GNSS_AGPS_Application_Note_V1.1.pdf (1.2 MB) Quectel_MC60_Series_GNSS_AT_Commands_Manual_V1.3.pdf (814.9 KB) Quectel_MC60_Series_GNSS_Protocol_Specification_V1.1.pdf (1.0 MB)
I trying everything. But not solve my GNSS issue.
hi, Pronay97:
Please describe your problem in detail, if there is a related problem log, please upload;Based on your description or log, we will conduct relevant analysis and solve your problem!
i have 5 device with MC60 GNSS issue, my GPS signal is weak after used more than 1 year.
my device use passive antena GNSS, i have replace GNSS antena, but the problem not solved.
can you help me ?
sorry if my english is bad.
thanks & regards
Are your GPS signals still weak out in the open?
Yes, but after replace with new device, GNSS signal is good in same place
Can you switch to another MC60 module? so,Check whether the module is abnormal by cross-test
Do you have another solution?
Because if change MC60, the imei has been changed too
You can also swap the antenna of the abnormal device with that of the normal device
I can do that, but GNSS signal still weak
Ohhh, we need to confirm whether the module performance is abnormal, so we need you to replace the new module for debugging
