Hello guys,
I am working on Quectel M65 module. I am using opencpu approach. I want your help regarding following topics.
1] how to create FOTA pack file using “Create FOTA pack tool” available in the /tool/x directory.
2] What configuration should i use in the tool
3] How do i get/set Code Flash Base & Code Flash size.
Thank you.
- I have sent the document to you privately for your reference
2.You can refer to the Packaging Application configuration in the documentation
3.Code Flash Base & Code Flash size follow the Settings in the document
thank you very much for your help
Hi. I am stuck at same issue. The application note is in Chinese and unable to understand. Please share the process. Thanks
Vinay
