I am trying to connect Nvidia Jetson Nano singale board computer to a 5G network using Quectel RM500 modules. Do you have any guide how to properly install Quectel_LTE5G_Linux_USB_Drivers on Linux-tegra 4.9.253 OS?
Is it RM500Q or RM400U, or any else?
If you will not compile the kernel for the OS, you have to compile the driver as kernel modules.
Hi thank you for the reply. I compiled the kernel to the OS. However I could not see WWAN driver and GobiNet driver installed. Usb serial option driver was there so I could do AT commands.
Can I know do I need to have WWAN driver and GobiNet driver installed in order to use the RM500Q as modem?
Could you provide the dmesg log?
Please show the result:
cat /sys/kernel/debug/usb/devices
