Hello
I am going to use the Quectel LTE module to connect the Azure IoT hub over TLS/SSL connection.
As I read AT command manuals of some Quectel LTE modules. it says that SSL’s maximum data length is 1500 bytes. for example command AT+QSSLRECV - Integer type. The length of data to be retrieved. Range: 1–1500. Unit: byte.
As per our device requirement, we need to send up to 3kb of data from the Azure IoT hub to the device, and that’s why I am interested in how I can retrieve the whole message if the max buffer length is 1.5kb.
I appreciate any help you can provide.
