Quectel LC86l capacitor for power supply
Dear Sir/Madam,
I am currently using the Quectel LC86L module with an Arduino Pro Mini. The entire system is powered at 3.3V. In my circuit, I have a MOSFET that disconnects the main VCC power supply to the Quectel module, but the VBAT pin remains connected to 3.3V (from arduino).
I would like to ask if this setup is appropriate at this voltage level, or would you recommend adding additional capacitors for stability?
Hi @Adam_Sz
Apologies for the late reply
Can you confirm the module you are using is L80-R or LC86L?
I am replying based on the SCH provide which is L80-R
Please follow the hardware design reference shown in the picture
Best regards
