I am not using at commands to bring up the Quectel L76L GPS module.
The power is given properly to the board that we are using and we believe its not hardware or power issue.
However i want to know if the power on sequence with GPIO is correct or not
The standby pin is always high in our case and marked as unused
The forceon pin has been pulled high
and the reset pin is pulled high
After this i am tracing the uart pins with logical analyser to see if some data comes from gps module L76L but unfortunately i am not seeing anything over the uart. Could you please help guide me if anything i am doing is wrong
Hi ajaraj,
Could you please provide information on your firmware version? You can check it through command:
$PQVERNO,R*3f
Best regards
