Quectel Forums Experience Feedback
Dear Quectel Customer,
Thank you for your continued interest in and use of the Quectel Forums.
To help us continuously improve the Quectel Forums. We sincerely invite you to spend 1–3 minutes completing this survey. We would love to hear about your real experience with finding materials, posting questions, and browsing documentation in the Forums.
Every piece of feedback you provide will directly drive the next round of Quectel Forums improvements.
In addition, if you have any thoughts or suggestions regarding the SDK, documentation, or toolchains during your development process, you are also welcome to include them in the survey.
Participation Methods (choose any one):
  • Click the “Feedback” button in the lower-right corner of the Forums page to complete the survey.
  • Click the survey link in this post to complete the survey.
  • Scan the QR code on the poster to complete the survey.
Survey Link: 移远问卷-QuecShow
Note: For technical issues support, we recommend you visit the relevant category for discussion. Thank you for your cooperation. :blush:
:wrapped_gift: Reward: To thank you for your participation, we will select those who provide detailed feedback and constructive suggestions and offer gift cards.
HI, we need support to reset or reprogram the stop working modules. around we are using 8000 modules from that we have 200 defective which are network not connecting. we are looking firmware along with flash tools.
hello, @SHYAM could you tell us you current firmware version,and details of the issue, i will loop the moderator to support you, thanks~
EC25CGAR06A09M1G the issue for all sim not deduct.
@NikiWe have successfully flashed 40 out of 200 units with EC25-EC modules using firmware version EC25ECGAR06A16M1G, and these units are functioning correctly.
However, we are facing a serious issue with the remaining units. These modules are not detecting the SIM even after flashing the same firmware.
Also we are finding more two types of issues during the flashing process of the EC25-EC1 modem:
  1. Only COM Port 11 is Detected:
    During flashing, the system only shows COM port 11. No other expected COM ports appear after flashing also same.
  2. Module Not Powering On – No COM Port Displayed:
    In some cases, the module does not power on at all, and consequently, no COM port is displayed in the flashing tools.
@AnnaLiu Hi Anna, could you please help to support this issue? Many thanks~
hi,
Sorry for the late reply.
May I ask if the current module can still send AT commands? Could you please provide detailed version information? Use the command to check. Is the current problem with the module caused by the firmware update? If you can send the AT command, please execute “at+cfun?”. Check the status.
[2025-09-08 05:31:07:209_R:] AT+CPIN?
[2025-09-08 05:31:07:246_R:] +CME ERROR: SIM not inserted
[2025-09-08 05:32:01:665_S:] AT+QGMR
[2025-09-08 05:32:01:680_R:] AT+QGMR
[2025-09-08 05:32:01:696_R:] EC25ECGAR06A16M1G_20.300.20.300
[2025-09-08 05:32:01:696_R:] OK
[2025-09-08 05:34:22:825_R:] at+cfun
[2025-09-08 05:34:22:847_R:] ERROR
[2025-09-08 05:38:39:259_S:] AT+CFUN=0
[2025-09-08 05:38:39:265_R:] AT+CFUN=0
[2025-09-08 05:38:39:498_R:] OK
Dear Team,
Kindly review the report below and consider the issue that has been highlighted.
Please let me know if any further information is required.
/* Use ATI to get module information of Manufacturer ID, Device module and Firmware version */
[2025-09-09 22:00:59:867_S:] ATI
[2025-09-09 22:00:59:883_R:] ATI
[2025-09-09 22:00:59:883_R:] Quectel
[2025-09-09 22:00:59:883_R:] EC25
[2025-09-09 22:00:59:883_R:] Revision: EC25ECGAR06A16M1G
[2025-09-09 22:00:59:883_R:] OK
/* Use AT+GSN to query the IMEI of module */
[2025-09-09 22:00:59:898_S:] AT+GSN
[2025-09-09 22:00:59:914_R:] AT+GSN
[2025-09-09 22:00:59:930_R:] 862757054771672
[2025-09-09 22:00:59:930_R:] OK
[2025-09-09 22:00:59:930_S:] ATI
[2025-09-09 22:00:59:945_R:] ATI
[2025-09-09 22:00:59:945_R:] Quectel
[2025-09-09 22:00:59:945_R:] EC25
[2025-09-09 22:00:59:945_R:] Revision: EC25ECGAR06A16M1G
[2025-09-09 22:00:59:945_R:] OK
[2025-09-09 22:00:59:967_S:] AT+QURCCFG=“URCPORT”,“usbat”
[2025-09-09 22:00:59:967_R:] AT+QURCCFG=“URCPORT”,“usbat”
[2025-09-09 22:00:59:967_R:] OK
/* Use AT+CPIN? to query the SIM card status : SIM card inserted or not, locked or unlocked */
[2025-09-09 22:00:59:999_S:] AT+CPIN?
[2025-09-09 22:01:00:014_R:] AT+CPIN?
[2025-09-09 22:01:00:030_R:] +CME ERROR: SIM not inserted
/* Make sure SIM card is unlocked */
[2025-09-09 22:01:03:385_S:] AT+CPIN?
[2025-09-09 22:01:03:409_R:] AT+CPIN?
[2025-09-09 22:01:03:438_R:] +CME ERROR: SIM not inserted
dear team, please check the below report & give us solution.
[2025-09-10 00:47:52:369_S:] AT+CPIN?
[2025-09-10 00:47:52:387_R:] AT+CPIN?
[2025-09-10 00:47:52:397_R:] +CPIN: READY
[2025-09-10 00:47:52:397_R:] OK
/* Use AT+CIMI to query the IMSI of SIM card */
[2025-09-10 00:47:52:427_S:] AT+CIMI
[2025-09-10 00:47:52:438_R:] AT+CIMI
[2025-09-10 00:47:52:453_R:] 901280029243604
[2025-09-10 00:47:52:453_R:] OK
/* Use AT+QCCID to query ICCID number of SIM card */
[2025-09-10 00:47:52:487_S:] AT+QCCID
[2025-09-10 00:47:52:507_R:] AT+QCCID
[2025-09-10 00:47:52:517_R:] +QCCID: 89882390000195277259
[2025-09-10 00:47:52:517_R:] OK
/* Use AT+CSQ to query current signal quality */
[2025-09-10 00:47:52:538_S:] AT+CSQ
[2025-09-10 00:47:52:553_R:] AT+CSQ
[2025-09-10 00:47:52:562_R:] +CSQ: 31,99
[2025-09-10 00:47:52:562_R:] OK
/* Use AT+CREG? /AT+CGREG? to query the network registration status. */
[2025-09-10 00:47:52:587_S:] AT+CREG?
[2025-09-10 00:47:52:597_R:] AT+CREG?
[2025-09-10 00:47:52:607_R:] +CREG: 0,3
[2025-09-10 00:47:52:607_R:] OK
[2025-09-10 00:47:52:619_S:] AT+CGREG?
[2025-09-10 00:47:52:636_R:] AT+CGREG?
[2025-09-10 00:47:52:636_R:] +CGREG: 0,3
[2025-09-10 00:47:52:636_R:] OK
[2025-09-10 00:47:53:653_S:] AT+CREG?
[2025-09-10 00:47:53:670_R:] AT+CREG?
[2025-09-10 00:47:53:670_R:] +CREG: 0,3
[2025-09-10 00:47:53:670_R:] OK
[2025-09-10 00:47:53:686_S:] AT+CGREG?
[2025-09-10 00:47:53:686_R:] AT+CGREG?
[2025-09-10 00:47:53:686_R:] +CGREG: 0,3
[2025-09-10 00:47:53:686_R:] OK
[2025-09-10 00:47:54:719_S:] AT+CREG?
[2025-09-10 00:47:54:735_R:] AT+CREG?
[2025-09-10 00:47:54:736_R:] +CREG: 0,3
[2025-09-10 00:47:54:736_R:] OK
[2025-09-10 00:47:54:753_S:] AT+CGREG?
[2025-09-10 00:47:54:774_R:] AT+CGREG?
[2025-09-10 00:47:54:774_R:] +CGREG: 0,3
[2025-09-10 00:47:54:774_R:] OK
[2025-09-10 00:47:55:809_S:] AT+CREG?
[2025-09-10 00:47:55:837_R:] AT+CREG?
[2025-09-10 00:47:55:837_R:] +CREG: 0,3
[2025-09-10 00:47:55:837_R:] OK
[2025-09-10 00:47:55:870_S:] AT+CGREG?
[2025-09-10 00:47:55:870_R:] AT+CGREG?
[2025-09-10 00:47:55:886_R:] +CGREG: 0,3
[2025-09-10 00:47:55:886_R:] OK
[2025-09-10 00:47:56:920_S:] AT+CREG?
[2025-09-10 00:47:56:953_R:] AT+CREG?
[2025-09-10 00:47:56:969_R:] +CREG: 0,3
[2025-09-10 00:47:56:969_R:] OK
[2025-09-10 00:47:56:986_S:] AT+CGREG?
[2025-09-10 00:47:56:986_R:] AT+CGREG?
[2025-09-10 00:47:57:003_R:] +CGREG: 0,3
[2025-09-10 00:47:57:003_R:] OK
/* Make sure the Antenna is connected and the network is normal */
hi,
From the current log, it appears that the module registration was rejected.
Next step:
  1. Please check the following AT command. Confirm whether the APN settings are correct.
    AT+CGDCONT?
  2. May I ask if you have previously retrieved the QXDM logs?
[2025-09-10 08:36:32:066_S:] AT+CGDCONT?
[2025-09-10 08:36:32:066_R:] AT+CGDCONT?
[2025-09-10 08:36:32:082_R:] +CGDCONT: 1,“IP”,“mow3.vodafone.com.qa”,“0.0.0.0”,0,0,0,0
[2025-09-10 08:36:32:082_R:] OK
Although there is an APN, the IP has not been obtained. So the registration was rejected.
then what is next steep?
@AnnaLiu can you send me EC25-EUX latest firmware.
Hi, thanks for sharing the survey info. We really appreciate the support from Quectel. We’re also facing some issues with a few modules not connecting to the network. It would be great if the team could share firmware files or tools to help us reset or reprogram the defective ones.
Hello Quectel Team,
I guess that a proper survey is to hear customer’s perspectives and opinions / feedbacks concerning Quectel products overall. Not being a support or helpdesk area.
So, the support topics should be moved to the appropriated sections or hardware topics, keeping Quectel User Experience(UX) and Product Survey free for being written new feedbacks, suggestions and any other ideas or views that could improve the products, software, tools and documentation.
Mixing everything in everywhere shows a deep lack of organization. It does not matter if a customer is small or big. At the end of the day, a clean and organized forum helps everyone find information, share experiences, get help and learning to get the best of what the product can offer.
Well, my suggestion is to have a single software tool, with the concept of Qnavigator, organized in tabs that the user can choose wich function can be used, for instance: configure gnss in one tab, AT commands in the second tab, make calls and send SMS in the third one, diagnostic tools in the fourth or more tabs, online documentation in the another, and so on… A single powerfull tool that have every single function for every Quectel products.
It will be not only more practical, but also will reduce the quantity of tools that we have to download, giving to the user much more flexibility, options, and power to get the best of Quectel products.
