Hello i would like to get the newest Firmware for my Quectel EM05-G as it doesnt work anymore under Windows 11
Currently on EM05GFAR07A07M1G
Hi @cheems
I have send it to you via e-mail,pls chk.
Is it possible that this is a more general issue with the EM05-G and windows ?
I have a same issue with windows 11, also with EM05GFAR07A07M1G firmware version on a lenovo X13 Gen 4…
I have a weird issue where the modem is only functioning properly after going once into the BIOS settings. Then it’s able to properly find a network and connect to it. Whenever the computer goes in standy or reboots, the WWAN module always states that it’s unable to find a mobile network.
Thanks i got the Firmware but would also like to request the tools to perform the Update under Windows
Many thanks in advance
Please send it to me too!
Good day,
I have also EM05-G on EM05GFAR07A07M1G firmware (Lenovo Z16 - Win 11)
It shows yellow bang after each standby / device not working.
Driver: 10.0.22621.4391 - dd 16.10.2024 - Microsoft.
Pls supply driver and/or FW update to solve this issue…
(incl. instruction how to install)
can I also get the latest firmware and windows drivers for the EM05-G module
thanks.
Hello, I have a fleet of EM05-G modems that require the latest firmware update. Could you please send the firmware and update instructions?
Thank you.
Same here, if anybody has it it would be great
Thanx
Hi Sir
What is your current firmware version? Much appreciation
I’m also stuck at firmware EM05GFAR07A07M1G and can not get it running on Linux. I added a nano-SIM card, but the module tries to find an eSIM…
─○ sudo mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: xxx
Hardware | manufacturer: Quectel
| model: Quectel EM05-G
| firmware revision: EM05GFAR07A07M1G
| h/w revision: QUECTEL Mobile Broadband Modul
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: xxx
System | device: /sys/devices/pci0000:00/0000:00:08.1/0000:c3:00.3/usb1/1-4
| physdev: /sys/devices/pci0000:00/0000:00:08.1/0000:c3:00.3/usb1/1-4
| drivers: option, cdc_mbim
| plugin: quectel
| primary port: cdc-wdm1
| ports: cdc-wdm1 (mbim), ttyUSB2 (at), ttyUSB3 (at), wwan0 (net)
Status | state: failed
| failed reason: esim-without-profiles
| power state: low
Modes | supported: allowed: 3g, 4g; preferred: none
| current: allowed: 3g, 4g; preferred: none
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: xxx
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/1
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0
| slot 2: /org/freedesktop/ModemManager1/SIM/1 (active)
Would like to give it a try with the latest firmware..
Hi @lyman-Q , still active here?
Hi my current firmware of EM05-E is EM05EFAR06A06M4G.
Can I get the latest firmware please? Thank you
Same here for EM05-G with EM05GFAR07A07M1G
Request latest firmware for EM05-G for Linux update via QFirehose.
My current version is: EM05GFAR07A07M1G
Hi, I have sent the latest firmware via email, pls check it, thank u.
Hi, I have sent the latest firmware and flashing tool via email, pls check it, thank u.
