According to the AT Commands Manual, “NO ANSWER” indicates the following:
From what I understand, this message appears when the modem rings, if there is silence for more than 5 seconds, the line is disconnected and resulting “NO ANSWER” code.
Could you please confirm if my understanding is correct?
Additionally, would it be possible to send the command “ATS7=0” to disable the “Set Time to Wait for Connection Completion” timer, thereby preventing the “NO ANSWER” message from appearing?
Thank you.
Antoine
