Quectel EC200U-CN strange behavior when querying GPS NMEA data
Hi everyone,
I have been using Quectel EC200U-CN for a while now, but recently, I got strange behavior when trying to obtain GPS data via NMEA GGA sentence.
Here’s what I did in the past that has been working perfectly:
AT+QGPSGNMEA=“GGA” returns with "+QGPSGNMEA: " and GGA sentence.
Now, with a different batch of the same module, it’s not working properly anymore:
AT+QGPSGNMEA=“GGA” returns with just “OK” and no GGA data !!!
Side notes: this batch contains five modules of EC200U-CN, two of them did return proper GGA for a short period of time, but then they ended up having the same fate as the other three.
Firmware version: EC200UCNLAR02A05M08.
Thank you in advance for your help.
Best regards,
Trung Le
Hi @trungle
Please make sure that the NMEA statement is not banned. Also be sure to test GNSS functionality outdoors in an open environment.
Hi Lyman-Q,
I double-checked everything and am certain that the NMEA statement is not disabled.
Also, I want to add that “AT+QGPS=1” did not return any NMEA data at all, I attempted to change the outport via AT+QGPSCFG=“outport”,“usbat” and waited for some minutes but still got nothing.
Here is an example of what should be returned using a normal working module:
Best regards,
Trung Le
Hi @trungle
I have sent you the QTTFF tool, which can test the GPS function more professionally. I have sent the link to the chat box. Can you try this tool? Or I see that your module has new firmware, would you like to try the latest firmware?
Facing similar issue with multiple modules of ec200u-cn
Could help me resolve this issue. Basically the evaluation board locks gps but multiple of our custom boards don’t work (gps lock not acquired) this was not a problem in our previous lots.
If I need to update any firmware is there a way I can do it via dfota or uart main
hi lyman could you me the QTTFF tool, am also facing the same kind problem while testing the gnss part.
