Hi Members, i am using Quectel CC200A-LB module for satellite communication. when i was giving commands some commands are working like ATI, AT+QGMR, AT+GSN, ATV, ATS3, ATS4 etc…but some commands are not working like AT+QSCN, AT+QREG, AT+QSMGL, AT+QSMGS, AT+QSMGT, AT+QSMGC, AT+QRMGS. i am giving 5V supply to the module and also i checked outside like clear sky. what is the mostly problem.
Is there any URC after executing above commands?
I am getting these serial message responses from the CC200A-LB.
I am using the JCB305L antenna.
i am using this module in the indoor apartment building.
what is the error see the firmware version in the serial messages.
related to satellite communication the AT commands are not working.
i am sharing the code for your reference plz find the attachment.
satellite_code.txt (7.1 KB)
09:39:21.135 → ATI
09:39:21.135 → Quectel
09:39:21.135 → CC200ALB
09:39:21.135 → Revision: CC200ALBAAR01A05M04
09:39:21.135 →
09:39:21.135 → OK
09:39:21.135 →
09:39:21.135 → Sending AT+QGMR command
09:39:21.349 → Expected response matched:
09:39:21.349 → AT+QGMR
09:39:21.349 → +QGMR: CC200ALBAAR01A05M04_01.002.01.002
09:39:21.349 →
09:39:21.349 → OK
09:35:55.465 → Expected message not received within timeout:
09:35:55.465 → AT+QGPS=?
09:35:55.465 → ERROR
09:35:55.465 →
09:35:55.465 → Failed3
09:36:10.436 → Expected message not received within timeout:
09:36:10.436 → AT+QGPS?
09:36:10.436 → ERROR
09:36:10.436 →
09:36:10.436 → Failed4
09:36:25.454 → Expected message not received within timeout:
09:36:25.454 → AT+QGPSEND=?
09:36:25.454 → ERROR
09:36:25.454 → Failed5
09:36:25.669 → Expected response matched:
09:36:25.669 → AT+QLAERR?
09:36:25.669 → +QLAERR: 101
09:36:25.669 →
09:36:25.669 → OK
09:36:25.669 →
09:36:25.852 → Expected response matched:
09:36:25.852 → AT+QURCCTL?
09:36:25.852 → +QURCCTL: 0x00FF
09:36:25.852 →
09:36:25.852 → OK
09:36:25.852 →
Hiii…still i am waiting for your reply…
