Hello Quectel Support Team,
I am using the EM060K-GL module in MBIM mode with a 4G SIM card. When I try to connect using Quectel-CM, the connection fails and returns:
[10-15_14:08:20:938] QConnectManager_Linux_V1.6.3.2
[10-15_14:08:20:941] Find /sys/bus/usb/devices/4-3 idVendor=0x2c7c idProduct=0x30b, bus=0x004, dev=0x002
[10-15_14:08:20:942] Auto find qmichannel = /dev/cdc-wdm0
[10-15_14:08:20:942] Auto find usbnet_adapter = wwan0
[10-15_14:08:20:942] netcard driver = cdc_mbim, driver version = 22-Aug-2005
[10-15_14:08:20:942] Modem works in MBIM mode
[10-15_14:08:20:977] cdc_wdm_fd = 7
[10-15_14:08:20:977] mbim_open_device()
[10-15_14:08:23:979] mbim_open_device:1660 err=110, Status=0
[10-15_14:08:23:979] mbim_open_device()
[10-15_14:08:26:574] mbim_device_caps_query()
[10-15_14:08:26:670] DeviceId: 867228050178374
[10-15_14:08:26:670] FirmwareInfo: EM060KGLAAR01A11M2G
[10-15_14:08:26:670] HardwareInfo: EM060K-GL
[10-15_14:08:26:670] mbim_device_services_query()
[10-15_14:08:26:734] mbim_set_radio_state( 1 )
[10-15_14:08:26:765] HwRadioState: 1, SwRadioState: 1
[10-15_14:08:26:765] mbim_subscriber_status_query()
[10-15_14:08:26:990] SubscriberId: 311480908795056
[10-15_14:08:26:990] SimIccId: 89148000012019108584
[10-15_14:08:26:990] SubscriberReadyState NotInitialized -> Initialized
[10-15_14:08:26:990] mbim_register_state_query()
[10-15_14:08:27:022] RegisterState Unknown -> Home
[10-15_14:08:27:022] mbim_packet_service_query()
[10-15_14:08:27:054] PacketServiceState Unknown -> Attached
[10-15_14:08:27:054] CurrentDataClass = LTE
[10-15_14:08:27:054] mbim_query_connect(sessionID=0)
[10-15_14:08:27:086] ActivationState Unknown -> Deactivated
[10-15_14:08:27:086] ifconfig wwan0 0.0.0.0
[10-15_14:08:27:093] ifconfig wwan0 down
[10-15_14:08:27:106] mbim_set_connect(onoff=1, sessionID=0)
[10-15_14:08:27:694] <03:00:00:80:54:00:00:00:0B:00:00:00:01:00:00:00:00:00:00:00:A2:89:CC:33:BC:BB:8B:4F:B6:B0:13:3E:C2:AA:E6:DF:0C:00:00:00:02:00:00:00:24:00:00:00:00:00:00:00:03:00:00:00:00:00:00:00:00:00:00:00:7E:5E:2A:7E:4E:6F:72:72:73:6B:65:6E:7E:5E:2A:7E:37:00:00:00:
[10-15_14:08:27:694] < Header:
[10-15_14:08:27:694] < MessageLength = 84
[10-15_14:08:27:694] < MessageType = MBIM_COMMAND_DONE (0x80000003)
[10-15_14:08:27:694] < TransactionId = 11
[10-15_14:08:27:694] < Contents:
[10-15_14:08:27:694] < DeviceServiceId = UUID_BASIC_CONNECT (a289cc33-bcbb-8b4f-b6b0-133ec2aae6df)
[10-15_14:08:27:694] < CID = MBIM_CID_CONNECT (12)
[10-15_14:08:27:694] < Status = 2
[10-15_14:08:27:694] < InformationBufferLength = 36
[10-15_14:08:27:694] < SessionId = 0
[10-15_14:08:27:694] < ActivationState = Deactivated (3)
[10-15_14:08:27:694] < IPType = MBIMContextIPTypeDefault
[10-15_14:08:27:694] < VoiceCallState = None
[10-15_14:08:27:694] < ContextType = 7e5e2a7e-4e6f-7272-736b-656e7e5e2a7e
[10-15_14:08:27:694] < NwError = 55
[10-15_14:08:27:694] mbim_set_connect:2011 err=0, Status=2
[10-15_14:08:27:694] try to requestSetupDataCall 5 second later
[10-15_14:08:32:695] mbim_set_connect(onoff=1, sessionID=0)
[10-15_14:08:33:137] <03:00:00:80:54:00:00:00:0C:00:00:00:01:00:00:00:00:00:00:00:A2:89:CC:33:BC:BB:8B:4F:B6:B0:13:3E:C2:AA:E6:DF:0C:00:00:00:02:00:00:00:24:00:00:00:00:00:00:00:03:00:00:00:00:00:00:00:00:00:00:00:7E:5E:2A:7E:4E:6F:72:72:73:6B:65:6E:7E:5E:2A:7E:37:00:00:00:
[10-15_14:08:33:137] < Header:
[10-15_14:08:33:137] < MessageLength = 84
[10-15_14:08:33:137] < MessageType = MBIM_COMMAND_DONE (0x80000003)
[10-15_14:08:33:137] < TransactionId = 12
[10-15_14:08:33:138] < Contents:
[10-15_14:08:33:138] < DeviceServiceId = UUID_BASIC_CONNECT (a289cc33-bcbb-8b4f-b6b0-133ec2aae6df)
[10-15_14:08:33:138] < CID = MBIM_CID_CONNECT (12)
[10-15_14:08:33:138] < Status = 2
[10-15_14:08:33:138] < InformationBufferLength = 36
[10-15_14:08:33:138] < SessionId = 0
[10-15_14:08:33:138] < ActivationState = Deactivated (3)
[10-15_14:08:33:138] < IPType = MBIMContextIPTypeDefault
[10-15_14:08:33:138] < VoiceCallState = None
[10-15_14:08:33:138] < ContextType = 7e5e2a7e-4e6f-7272-736b-656e7e5e2a7e
[10-15_14:08:33:138] < NwError = 55
[10-15_14:08:33:138] mbim_set_connect:2011 err=0, Status=2
[10-15_14:08:33:138] try to requestSetupDataCall 10 second later
[10-15_14:08:43:138] mbim_set_connect(onoff=1, sessionID=0)
Details:
- Module: EM060K-GL
- Mode: MBIM
- SIM: 4G (LTE)
- Quectel-CM version: QConnectManager_Linux_V1.6.3.2
- OS: Ubuntu 20.04.3 LTS
Problem:
The module fails to register to the network when dialing a 4G SIM in MBIM mode, showing NwError = 55.
Request:
Could you please clarify:
- What does NwError = 55 indicate?
- Is there a recommended way to configure Quectel-CM for 4G SIMs in MBIM mode on EM060K-GL?
- Are there any known limitations or workarounds?
Thank you for your support.
