At the beginning of the test, we establish data session with a APN using the quectel CM modem on LTE network. During the test, we run some attack scenario so quectel-CM gets disconnected . Once the attackl is tuned off and network is available , quectel-CM is not reestablishing the data session . I don’t see any “requectSetupDataCall WdsConnection message” . I tried to trigger the data session by running quectel-CM again with the APN name ( ./quectel-cm -s wirelessone.com) but that didn’t work
How can I trigger requestSetupDataCall WdsConnectionIPv4Handle so wwan0 interface is up and obtains an IP
When data session gets setup:
[06-11_08:07:14:808] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[06-11_08:07:14:809] ifconfig wwan0 0.0.0.0
[06-11_08:07:14:826] ifconfig wwan0 down
[06-11_08:07:14:904] requestSetupDataCall WdsConnectionIPv4Handle: 0xf250b1f0
[06-11_08:07:15:032] ifconfig wwan0 up
[New Thread 0x7ff532f1d0 (LWP 2389)]
[06-11_08:07:15:065] busybox udhcpc -f -n -q -t 5 -i wwan0
udhcpc: started, v1.27.2
No resolv.conf for interface wwan0.udhcpc
udhcpc: sending discover
udhcpc: sending select for 192.168.2.14
udhcpc: lease of 192.168.2.14 obtained, lease time 7200
data session is down after the attack
[06-11_08:07:26:904] requestRegistrationState2 MCC: 310, MNC: 1, PS: Detached, DataCap: LTE
[06-11_08:07:26:936] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[06-11_08:07:26:936] ifconfig wwan0 0.0.0.0
[06-11_08:07:26:965] ifconfig wwan0 down
[06-11_08:07:30:360] requestRegistrationState2 MCC: 310, MNC: 1, PS: Detached, DataCap: UNKNOW
