The same problem here.
root@xxx:/data/home/root# quectel-CM
[03-13_13:46:59:404] QConnectManager_Linux_V1.6.7
[03-13_13:46:59:413] Find /sys/bus/usb/devices/1-1 idVendor=0x2c7c idProduct=0x125, bus=0x001, dev=0x002
[03-13_13:46:59:419] Auto find qmichannel = /dev/cdc-wdm0
[03-13_13:46:59:420] Auto find usbnet_adapter = wwan0
[03-13_13:46:59:421] netcard driver = qmi_wwan, driver version = 22-Aug-2005
[03-13_13:46:59:423] unsupport software_interface 1
root@xxx:/data/home/root# quectel-CM -v
[03-13_13:59:55:528] QConnectManager_Linux_V1.6.7
[03-13_13:59:55:532] (/sys/bus/usb/devices/1-1/idVendor) = 2c7c
[03-13_13:59:55:534] (/sys/bus/usb/devices/1-1/idProduct) = 125
[03-13_13:59:55:536] (/sys/bus/usb/devices/1-1/busnum) = 1
[03-13_13:59:55:537] (/sys/bus/usb/devices/1-1/devnum) = 2
[03-13_13:59:55:539] (/sys/bus/usb/devices/1-1/bNumInterfaces) = 5
[03-13_13:59:55:543] Find /sys/bus/usb/devices/1-1 idVendor=0x2c7c idProduct=0x125, bus=0x001, dev=0x002
[03-13_13:59:55:546] (/sys/bus/usb/devices/1-1:1.4/bNumEndpoints) = 3
[03-13_13:59:55:547] (/sys/bus/usb/devices/1-1:1.4/bInterfaceClass) = ff
[03-13_13:59:55:549] (/sys/bus/usb/devices/1-1:1.4/bInterfaceSubClass) = ff
[03-13_13:59:55:550] (/sys/bus/usb/devices/1-1:1.4/bInterfaceProtocol) = ff
[03-13_13:59:55:551] driver → ../../../../../../../../../bus/usb/drivers/qmi_wwan
[03-13_13:59:55:553] /sys/bus/usb/devices/1-1:1.4/usbmisc
[03-13_13:59:55:555] Auto find qmichannel = /dev/cdc-wdm0
[03-13_13:59:55:556] Auto find usbnet_adapter = wwan0
[03-13_13:59:55:556] netcard driver = qmi_wwan, driver version = 22-Aug-2005
[03-13_13:59:55:557] unsupport software_interface 1
The requested outputs are:
+QCFG_ “usbnet”,0
and
root@xxx:/sys/class/net# lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=ci_hdrc/1p, 480M
|__ Port 001: Dev 003, If 0, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 001: Dev 003, If 1, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 001: Dev 003, If 2, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 001: Dev 003, If 3, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 001: Dev 003, If 4, Class=Communications, Driver=[none], 480M
|__ Port 001: Dev 003, If 5, Class=CDC Data, Driver=[none], 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=ci_hdrc/1p, 480M
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=ci_hdrc/1p, 480M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/3p, 480M
uname -a
Linux 5.4.278-rt91
