Quectel BG95-M5: Crash when test RF
I’ve some problems with the BG95 module when we try to test RF with AT command AT+QRFTEST. The module works for GSM test but crash with LTE test.
We are following the application notes “BG95&BG77&BG600L Series FTM Application Note V1.1”. Commands are taken from the example at the end of the document.
  1. Connect through USB with QCOM_V1.6.
  2. Send command:
    ATI;+QGMR
    Receive:
BG95-M5
Revision: BG95M5LAR02A03
BG95M5LAR02A03_01.004.01.004
  1. Send command:
    AT+QRFTESTMODE=1
    Receive:
  2. Send command:
    AT+QRFTEST="GSM900",122,"ON",0,100
    Receive:
    I can see a wave at 900MHz on the spectrum analyzer.
  3. Send command:
    AT+QRFTEST="GSM900",122,"OFF",0,100
    Receive:
    No wave, normal.
  4. Send command:
    AT+QRFTEST="LTE BAND20",24300,"ON",50,1,100,0,50,4,0
    Crash. I tried with other bands and there are crashes too.
Thank you
I’ve the same error with the latest firmware BG95M5LAR02A03_01.008.01.008
Hi, I think it’s not the good installer (QPST instead of QWINLOG). I can’t fin QWINLOG, can you provide me a link to download it?
Thank you,
Jean
Here is the dump (Transfer not found – TransferNow). I can’t attach a file because I’m a new user.
QCOM log:
BG95-M5
+QRFTESTMODE: 1
Thank you
Thanks,
Seems i cannot acess this link, could you please share with onedriver or send to my emial(linkin.wang@quectel.com)
I just sent you an email
I got it Thanks.
BTW,Have you configured AT+QCFG=“nwscanmode”,3 to fixed LTE-CATM1 ?
Not in the dump but I just tried and I have the same crash
Hi Jeanbie,
Sorry for late response.
When you switch FTM test from GSM to LTE, you need reboot module then do LTE FTM test.
And this is required, could you please help do a test once more?
No problem.
When I reboot the module, the FTM test mode is reset to 0.
What I also do in my test (with the same crash) is just:
AT+QRFTESTMODE=1
Regards,
Jean
Hi @Linkin-Q ,
Do you find something ?
On your side, do you succeed to perform LTE FTM test on BG95 ?
Thank you,
Jean
Hi Jean,
Sorry for the late response.
Yes i tried in my side but cannot reproduce it. could you please help collect crash log ?
B R
Linkin WANG
Hi @Linkin-Q ,
It’s working on your side? Can you send me the exact command list that you used?
I’ll try with an evaluation board.
Regards,
Jean
hello @jeanbie i had the same probleme and i’m looking for a solution did you find anything useful ?
Hello @ibrakadabra
I think that the solution is to put a SIM card to perform the test. Maybe you need to remove the SIM card, I don’t remember exactly, but it was SIM card related.
