Hello there,
Does rshell work as py scripts uploader ?
>>> rshell
>>> cp path/main.py /pyboard/main.py
Hello there,
>>> rshell
I have one more question
Where to find QuecPython Stubs ?
hello, Do you mean the correspondence between the pin number and the GPIO number?
Please refer to the link below:
https://python.quectel.com/wiki/#/en-us/api/QuecPythonClasslib?id=pin
Screenshots is from my new tool ( VSCode / PlatformIO )
RSHELL is remote microPython shell, I ask if it works for Quectel modules
if not - is there a file uploader (preferably a python script)
and from where to find microPython stubs
The problem is that, this tool is not cross-platform
that’s why I’m asking, is there a script uploader (cross-platformed)
or source code to make an uploader ( Python ) as RSHELL
Sorry, maybe I don’t understand your question. Do you mean you don’t debug in the windows environment? Can you elaborate on the problems when using QPYCOM?
I make cross-platform ( Windows, Linux, Darwin… etc ) Tool ( as IDE )
based of VSCode + PlatformIO ( editor + builder )
The Tool / IDE support QuecPython:
Create a QuecPython project
Write / Edit QuecPython code
Lint QuecPython code ( syntax checking … The GIF shows the effect )
for linting code I need QuecPython Stubs
The Stub files contain type-hinting information of normal Python modules…
They look very similar to C header files in that they contain only the function signatures, but their use is purely optional…
Lint (software) - Wikipedia
Upload PY code to module
To be cross-platform tool, the uploader must be writen of Python
Your tools is only for Windows
ALL microPython boards use open source shell ( as RSHEL ) to uploading python code to modules
so, are you have shell to module or uploader source code to make own uploader
