NPU Image Classification Demo on PI-SG565D (ResNeXt50 + ImageNet)
The PI-SG565D board leverages NPU acceleration for deep learning applications such as:
Image classification
Object detection
Semantic segmentation
In this demo, we deploy a ResNeXt50 quantized model trained on the ImageNet dataset for image classification. This model can also serve as a backbone for more advanced custom AI applications.
Model & Files Download
Download the required files below:
ResNeXt50 Quantized Model (*
resnext50_quantized.tflite) -
ImageNet Labels (*
imagenet_labels.txt)
Deploy Files to Device via ADB
Connect the device via ADB and push the required files into the /opt directory:
adb push "C:\Users\yikai.chang\Downloads\resnext50_quantized.tflite" /opt
adb push "C:\Users\yikai.chang\Downloads\imagenet_labels.txt" /opt
Push Demo Video (Required)
Important: The demo will not run properly without a video file.
Push the sample video into the device:
adb push "C:\Users\yikai.chang\Downloads\video11.mp4" /opt
You may replace video11.mp4 with your own filename if needed.
Hardware Setup
Ensure the following are properly connected before running the demo:
Display output (HDMI or MIPI)
In this example, a MIPI 8-inch display is used
Environment Setup
Configure Wayland display environment:
Run NPU Classification Pipeline
Execute the following GStreamer pipeline to start real-time inference:
gst-launch-1.0 -e --gst-debug=2 \
filesrc location=/opt/video11.mp4 ! qtdemux ! queue ! h264parse ! v4l2h264dec capture-io-mode=5 output-io-mode=5 ! queue ! tee name=split \
split. ! queue ! qtivcomposer name=mixer sink_1::position="<30, 30>" sink_1::dimensions="<640, 360>" ! queue ! waylandsink sync=true fullscreen=true \
split. ! queue ! qtimlvconverter ! queue ! qtimltflite delegate=external external-delegate-path=libQnnTFLiteDelegate.so \
external-delegate-options="QNNExternalDelegate,backend_type=htp;" model=/opt/resnext50_quantized.tflite ! queue ! qtimlvclassification \
threshold=35.0 results=5 module=mobilenet labels=/opt/imagenet_labels.txt extra-operation=softmax \
constants="Resnetnet,q-offsets=<30.0>,q-scales=<0.06314703077077866>;" ! video/x-raw,format=BGRA,width=256,height=144 ! queue ! mixer.
Notes
The highlighted section can be modified depending on your video filename.
Ensure all required files exist in
/optbefore execution. -
Missing video or model files will cause pipeline failure.
Expected Output
Once executed successfully, the display will show:
Live video playback (overlay window)
Real-time classification results from NPU inference
Top-5 predicted labels from ImageNet dataset
Example Behavior
When the video shows a single object (e.g., “cock”), the model outputs one dominant class.
When multiple objects appear (e.g., “cock and hen”), multiple classification results may appear depending on confidence scores.
The label mapping can be referenced from imagenet_labels.txt.
Summary
This demo demonstrates how the PI-SG565D NPU can efficiently run ResNeXt50 image classification using TensorFlow Lite with hardware acceleration, while simultaneously processing video input in real time.
