QuecOpen SDK changed the IMEI of EG915NEU-AG
I have to build an application for Quectel EG915NEU-AG using QuectOpen SDK version LTE01R03A31_C_SDK_A. I program the resulting application with the adownload tool. Everything is working properly, except that the IMEI of the device changed to some default value: 864430010001091
Can you please advice how should I setup my build environment so that I do not change the IMEIs of the device that I program? How can I restore the original IMEI of that particular device?
Plamen
Hi,@defun
This issue is caused by the erasure of the parameter partition. The system uses the default IMEI and cannot be recovered. Perhaps the tool you used performed a partition erasure operation? This should have no relation to the SDK build environment.
