Quecopen crash on start
Is there any way to delete quecopen application using bootloader or something?
I have downloaded the application which crashes at the begining and now my BG95-M3 restarts all the time.
Which is strange it probably crashes on the lin:
qapi_UART_Power_On(&uart_handle);
Is there anything I can do? I have UMTS&LTE EVB_V2.2
Hi
find pin USB_BOOT and connect to VDD_EX( 1.8v ) then power-on and reflash module
wizio
:+1: :+1: :+1:
@WizIO @Stephen.Li-Q I’ve managed to reflash the module but still the module keeps reseting. Any idea what is wrong?
Should I flash firmware which doesn’t support QuecOpen? is there any firmware like that?
Hi
we not have source for analysis…
try check/debug uart_handle == NULL or other variable for NULL
if firmware not support ThreadX will not start user application
@WizIO The problem is I cannot download my firmware to BG95-M3 because it keeps reseting.
I’ve managed to flash processor using USB_BOOT pin but still it restarts all the time(boot → restart → boot → …).
It looks like the processor is still loading my previous quecopen application even after flashing it.
yep … same as me at first days with BG95 :slight_smile:
my solution:
I modified my python uploader to write ( very fast ) empty file ( oem_app_path.ini ) to UFS
After all I got a new firmware from quectel which deletes datatx contents.
Thanks for help @WizIO @Stephen.Li-Q
hint:
in developer stage I use SIM card as “pause key”… ( or wait 5, 6 seconds )
main() begin with wait_sim_ready()… if have problems with application, I remove sim card and reset module
app waithing sim and usb is OK to remove “bad” app
Thanks, great idea.
I used sleep for now, but this seems much better.
Also just in case I kept the firmware which deletes /datatx/ contents.
I am also facing the same issue when I turn on the board it is crashing and com port is disabled, due to this I am not able to remove the bin file in datax directory.i also tried usb boot pin to vdd_ext pin but I am not able to upload anything. Can you suggest me a way or something how can I get rid of this and remove the contents in datax directory.
