QPY_OCPU_V0005_EC800M_CNLE_FW optional SMS Module
Hey, I’m using an E800M-LE module.
I used the following firmware for it:
QPY_OCPU_V0005_EC800M_CNLE_FW V0005 2025-04-17
It works very well so far. Unfortunately, the “SMS module” is missing. According to the description, this is only optional.
“Supports TTS, Audios, Record, module plug-in GNSS, LCD, Lvgl, Ethernet, FOTA, WiFiSCAN, USSL, optional SMS, etc.”
Is there a suitable firmware with an integrated SMS module?
Hello, I have the same problem, I have an EC800M-CN-LE device which I was trying to program to check if they are suitable for a big work I have to do. But stumbled upon this:
>>> help('modules')
G711              cellLocator_qpy   micropython       uerrno
MCP2515           checkNet          misc              uhashlib
SecureData        checksum          modem             uio
TenCentYun        cmath             net               ujson
__main__          copy              ntptime           umqtt
__wifiLocator     dataCall          osTimer           unzip
_boot             dial              pm                uos
_thread           ethernet          ql_fs             uping
_uasyncio         event_message     queue             urandom
aLiYun            example           request           ure
app_fota          file_crc32        sensor            uselect
app_fota_download file_sha256       sim               usocket
app_fota_mount    fota              slip              ussl
app_fota_updater  gc                sys               ustruct
atcmd             gnss              sys_bus           usys
audio             hashlib           system            utils
backup_restore    hls               time              utime
bak_util          hmac              types             uwebsocket
base64            hmacSha1          uarray            uzlib
binascii          log               ubinascii         websocket
builtins          lvgl              ucollections      wifiScan
camera            machine           ucryptolib        wifilocator
cellLocator       math              uctypes           ymodem
Plus any modules on the filesystem
It seems sms module is missing, if I will have to reconfigure hundreds of these devices it would be very difficult to do it one by one without the possibility to send sms, so is it possible to have the full firmware? Thank you!
The EC800M_CN_LE does not have SMS functionality enabled initially; the manual indicates it needs to be updated.
While this function can be enabled, it only supports NAS SMS due to VoLTE support. In China, only China Mobile and China Unicom can send SMS messages normally.
It is recommended to use the EC800M_CN_LE_VOLTE version, which supports full SMS functionality.
I have sent you the new VoLTE firmware version via email. Please check and test it.
hello, I have the same issue. Can I have the new FW? Thanks
Yeah of course! I have sent it to you via email.
I have not received it.
Sry. Please check again.
hello can you send to me EC800M_CN_LE_VOLTE firmware.
thanks
