The band-scan feature (+QOPS) is great, but I’m experiencing a problem sometimes.
I use this sequence of commands to request a band scan:
I check attached/detached status of EG91:
AT+CGATT?
If the response indicates ATTACHED (1) then I send this command to DETACH:
AT+CGATT=0
Here are the commands and response to invoke the band scan:
send: AT+QCFG=“nwscanmode”
response: +QCFG: “nwscanmode”,0send: AT+QOPSCFG=“scancontrol”
response: QOPSCFG: “scancontrol”,3,0xffffffffbfffffff,0x7ffffdf3fff,0x3fsend: AT+QOPS
response: '+QOPS: “Verizon”,“Verizon”,“311480”
1,“4G”,5230,265,1904,63C502,-84,-13,0
2,“4G”,2600,66,1904,63C110,-111,-17,0
+QOPS: “AT&T”,“AT&T”,“310410”
1,“4G”,5110,471,8104,72CCE10,-95,-16,0
2,“4G”,1100,276,8104,72CDF09,-112,-13,0
3,“4G”,2000,337,8104,72CC017,-114,-19,0
4,“4G”,2250,337,8104,72CC0CA,-117,-19,0
+QOPS: “”,“”,“313100”
+QOPS: “T-Mobile”,“T-Mobile”,“310260”
1,“4G”,650,192,291F,15B9A0B,-102,-15,0
2,“4G”,2350,192,291F,15B9A01,-103,-15,0
The band scan works.
I can repeat the band scan, again and again, for hours at a time, and it continues to work. For example, I did more than 10,000 band scans, pausing for a couple of seconds between scans, and it worked without any problem.
However, if I wait for a while (at least a few minutes) after a band scan and then request a band scan, in exactly the same way, I don’t get any errors, but the response to,
AT+QOPS
is only:
Once that happens, it continues to happen every time I request a band scan. If I cycle the power then I can get a proper band scan, until I let enough time pass between band scans.
This problem is consistent. I can’t tell you exactly how long I must wait between band scans to see the problem, but I can say that if I wait 5 minutes between band scans the next band scan may give valid data or may just return OK.
I’ll be most grateful for advice and/or suggestions.
Regards,
Matt
