I have a problem with the Quectel Evaluation Kit with chipset sc600t-em.
The problem is that the connection procedure fails. What should I do?
i am using the UART port
hi,Star2909:
I suggest you use the serial port tool to debug and determine whether the serial port is faulty.
QCOM_V1.6.zip (715.5 KB)
Hi
I connect mc60 with usb to serial port and test with Qnavigate when i click Connect btn
ÿáèáØáØá/ÿplease try Qcom again
thanks, the problem was, my USB To Serial module. and i change it and solve .
i am also facing same issue can you help me
Please check the baud rate or adaptive voltage of your USB-to-serial tool
