+QMTOPEN: 0,-1 error
Hello, I am testing with a EC25 mini PCIe module and getting similar results with +QMTOPEN: 0,-1 as a response to the command QMTOPEN. I am also using AWS IoT core with SSL setttings and certificates, and our code has been tested with BG96 module working, so there should not be an issue about the certificates.
The firmware version of our module is EC25AFFAR07A08M4G.
Has anybody solved this issue? IS EC25 capable of working with AWS IoT core through MQTT?
This is a Log with the commands we are using.
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,1
AT+CEREG?
+CEREG: 0,1
AT+QNWINFO
+QNWINFO: “FDD LTE”,“310260”,“LTE BAND 2”,775
AT+QCSQ
+QCSQ: “LTE”,50,-78,188,-14
AT+GSN
866834041644845
AT+COPS?
+COPS: 0,0,“T-Mobile”,7
AT+GMR
EC25AFFAR07A08M4G
AT+QICSGP=1
+QICSGP: 1,“fast.t-mobile.com”,“”,“”,0
Performing AWS Provisioning
AT+QFDEL=“*”
AT+QFUPL=“RAM:cacert.pem”,1188,100
CONNECT
+QFUPL: 1188,2d13
AT+QFUPL=“RAM:user_key.pem”,1679,100
CONNECT
+QFUPL: 1679,4b38
AT+QFUPL=“RAM:client.pem”,1220,100
CONNECT
+QFUPL: 1220,3500
AT+QIACT?
AT+QIACT=1
AT+QMTCFG=“SSL”,0,1,2
AT+QSSLCFG=“clientcert”,2,“RAM:client.pem”
AT+QSSLCFG=“clientkey”,2,“RAM:user_key.pem”
AT+QSSLCFG=“cacert”,2,“RAM:cacert.pem”
AT+QSSLCFG=“seclevel”,2,2
AT+QSSLCFG=“sslversion”,2,4
AT+QSSLCFG=“ciphersuite”,2,0xFFFF
AT+QSSLCFG=“ignorelocaltime”,2,1
AT+QMTOPEN?
AT+QMTOPEN=0,“a1gfgsfcsg3p4-ats.iot.us-east-1.amazonaws.com”,8883
+QMTOPEN: 0,-1
Regards
Hi, I also meet this issue. I write in C code. And I turn the certificate into hex file, and add \r to end of each line, fail. Then \r\n, then \n, all fail. So how do you fix this?
Open your aws certificates in Notepadd++. and choose the format windows(CR LF) from the right side down. Then check the length displayed in the Notepad++. This should match with the numbers of characters you have written in your code
Is this format right? Each and of line shoud be /r/n(CRLF)? Or just /r(CR)?Or just /n(LF)
I put them into a cha buffer. Here is my log, I think the length is same with what you said in this issue.
[12:23:24.873]收←◆AT+QMTCFG=“SSL”,0,1,2
[12:23:27.837]收←◆AT+QMTCFG=“version”,0,4
[12:23:30.801]收←◆AT+QFUPL=“ufs:cacert.pem”,1208,100
CONNECT
ready to write
[12:23:31.902]收←◆Write CA!
[12:23:36.797]收←◆+QFUPL: 1208,5769
[12:23:39.760]收←◆AT+QFUPL=“ufs:clientcert.pem”,1244,100
CONNECT
ready to write
[12:23:40.868]收←◆Write certificate!
[12:23:45.761]收←◆+QFUPL: 1244,771c
[12:23:48.724]收←◆AT+QFUPL=“ufs:clientkey.pem”,1702,100
CONNECT
ready to write
[12:23:49.871]收←◆Write private key!
[12:23:54.765]收←◆+QFUPL: 1702,2f24
[12:23:57.730]收←◆AT+QSSLCFG=“cacert”,2,“ufs:cacert.pem”
[12:24:00.694]收←◆AT+QSSLCFG=“clientcert”,2,“ufs:clientcert.pem”
[12:24:03.657]收←◆AT+QSSLCFG=“clientkey”,2,“ufs:clientkey.pem”
[12:24:06.621]收←◆AT+QSSLCFG=“seclevel”,2,2
[12:24:09.585]收←◆AT+QSSLCFG=“sslversion”,2,4
[12:24:12.548]收←◆AT+QSSLCFG=“ciphersuite”,2,0XFFFF
[12:24:15.511]收←◆AT+QSSLCFG=“ignorelocaltime”,2,1
[12:24:21.414]收←◆AT+QMTOPEN=2,"a2q1awzao9n7sa-ats.iot.cn-northwest-1.amazonaws.c
+QMTOPEN: 2,0
[12:24:26.378]收←◆AT+QMTCONN=2,“Rak_Wisblock_Mqtt”
+QMTSTAT: 2,1
HI,
The Certificates size is ok. What is the hex value of CR and LF. it should be 0D and 0A.
if format is wrong the module will, return error
Can work only with /n
Right,CR and LF in the ASCII is 0x0D 0x0A. I put them in the a buffer, end of each line. But now I stuck here after
+QMTOPEN: 2,0
+QMTSTAT: 2,1
hi…
please download the example code for MQTT with SSL from below link.
Regards
Rahul
The connection seems to be closed by aws. Might be a client ID name issue or some policy issues with this ID. Check the aws configurations and ensure everything is right there
Hi All
Please find the below working AT logs for AWS SSL for EC2X. Hope so will help.
ATE1
AT+CGREG?
+CGREG: 0,1
+QIND: PB DONE
AT+COPS?
+COPS: 0,0,“IND airtel airtel”,0
AT+QICSGP=1,1,“airtelgprs.com”,“”,“”,1
AT+QIACT=1
AT+QIACT?
+QIACT: 1,1,1,“100.94.195.55”
AT+QFUPL=“RAM:cacert.pem”,1206,100
CONNECT
+QFUPL: 1206,5a63
AT+QFUPL=“RAM:clientcert.pem”,1220,100
CONNECT
+QFUPL: 1220,6118
AT+QFUPL=“RAM:clientkey.pem”,1675,100
CONNECT
+QFUPL: 1675,1612
AT+QMTCFG=“recv/mode”,0,0,1
AT+QSSLCFG=“clientcert”,2,“RAM:clientcert.pem”
AT+QSSLCFG=“clientkey”,2,“RAM:clientkey.pem”
AT+QSSLCFG=“ignoremulticertchainverify”,2,1
AT+QMTOPEN=0,“a1twhjugwcsoyn-ats.iot.us-west-2.amazonaws.com”,8883
+QMTOPEN: 0,0
AT+QMTCONN=0,“clientexample”
+QMTCONN: 0,0,0
AT+QMTPUB=0,1,1,0,“test/topic”
this is the test
+QMTPUB: 0,1,0
Hi Maker!, I’m getting the +QMTOPEN: 0,1 error in the bg96, How did you get rid of it? I’ve tried many different things but don’t work. :frowning: , I think it’s something when storing the certificates but I can not figure it out. These are the Commands I used:
QMTOPEN- 0,-1.pdf (18.0 KB)
Hi Azael ,
Please try your MQTT with MQTT.fx or some other application to check if your broaker is working fine .
If that is working then you can follow up example provided in BG96 MQTT application note .
How did you read the three files from memory?
You count last \r or not.
If your file are stored in UFS,you can use the following command to query:
AT+QFLST=“UFS:*”
Hii there, I am facing the same issue as yours while connecting my modem. I am using terminal to add my certificate files on modem. Can anyone guide me on how I should do it. I tried with \r\n, \r and \n, but nothing is working for me.
Also, I have generated certificates using OpenSSL, they are working fine when i try to establish connection with MQTTx, but I am facing problem while using them with GSM modem.
