QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 10
Dear Quectel Team,
We designed a board with using EC25-EC module and have connected it,over USB Interface, to our another board which runs Linux OS. In some cases especially if we plug a Wifi module to our system over an another USB connector, after a couple of time, we are getting below error codes. After these errors occur, then the system losses IP at wwan. Can you please specify that what is going wrong with the module?
Log Snippet:
requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:14:00:291] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:14:47:434] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:15:00:481] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:15:48:617] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:16:00:649] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:16:49:604] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:17:03:341] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:17:50:713] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:18:04:780] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:18:51:635] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:19:03:691] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:19:52:753] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:20:06:390] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:20:53:788] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:21:07:830] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:21:54:876] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:22:09:270] requestRegistrationState2 MCC: 286, MNC: 1, PS: Attached, DataCap: LTE
[02-14_14:22:55:341] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 2 (No such file or directory)
[02-14_14:22:55:341] requestQueryDataCall err = 110
[02-14_14:23:25:342] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 2 (No such file or directory)
[02-14_14:23:25:343] requestGetIPAddress err = 110
[02-14_14:23:55:435] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 2 (No such file or directory)
[02-14_14:23:55:435] requestDeactivateDefaultPDP err = 110
[02-14_14:24:25:525] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 2 (No such file or directory)
[02-14_14:24:25:526] requestQueryDataCall err = 110
[02-14_14:24:25:526] ifconfig wwan0 down
[02-14_14:24:25:645] ifconfig wwan0 0.0.0.0
[02-14_14:24:55:737] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 10 (No child processes)
[02-14_14:24:55:737] requestRegistrationState2 err = 110
[02-14_14:24:55:737] requestSetOperatingMode(1)
[02-14_14:25:25:738] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 10 (No child processes)
[02-14_14:25:25:738] requestSetOperatingMode err = 110
[02-14_14:25:25:739] requestSetOperatingMode(0)
[02-14_14:25:55:739] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 10 (No child processes)
[02-14_14:25:55:740] requestSetOperatingMode err = 110
[02-14_14:27:00:827] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 4 (Interrupted system call)
[02-14_14:27:00:827] requestRegistrationState2 err = 110
[02-14_14:27:00:827] requestSetOperatingMode(1)
[02-14_14:27:30:921] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 4 (Interrupted system call)
[02-14_14:27:30:921] requestSetOperatingMode err = 110
[02-14_14:27:30:921] requestSetOperatingMode(0)
[02-14_14:28:01:011] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 4 (Interrupted system call)
[02-14_14:28:01:011] requestSetOperatingMode err = 110
[02-14_14:28:36:101] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 4 (Interrupted system call)
[02-14_14:28:36:101] requestQueryDataCall err = 110
Regards,
Zafer Çalışkan
This symptom could be due to USB port is dropped by some reason. You would need to further check the modem status.
And here it’s the latest quectel-CM tool. We suggest to use this one:
https://cnquectel-my.sharepoint.com/:u:/g/personal/america-fae_quectel_com/EdcHLCWiXy9JgKiq-n4r_tkBY2T96tQRqgEZqkV5gMfpzA?e=pkU8on
Best Regards,
