Hello, I am trying to compile the qmi_wwan_q driver for OpenWrt since I am experiencing issues with the generic qmi_wwan driver on a private 5G network. The module I am using is the RG500Q-EA.
Since the Makefile provided with the source files is not adequate for OpenWrt I have created a new one with the following content:
include $(TOPDIR)/rules.mk
PKG_NAME:=qmi_wwan_q
PKG_VERSION:=1.2.2
PKG_RELEASE:=1
# Custom variable
SOURCE_DIR:=/home/crave/Documents/mypackages/qmi_wwan_q
PKG_MAINTAINER:=Quectel
include $(INCLUDE_DIR)/kernel.mk
include $(INCLUDE_DIR)/package.mk
define KernelPackage/qmi_wwan_q
SUBMENU:=Network
TITLE:=Quectel qmi_wwan driver
DEPENDS:= \
+kmod-mii \
+kmod-usb-core \
+kmod-usb-net-cdc-ether \
+kmod-usb-net \
+kmod-usb-net-qmi-wwan \
FILES:=$(PKG_BUILD_DIR)/qmi_wwan_q.ko
#AUTOLOAD:=$(call AutoLoad,50,qmi_wwan_q)
endef
define KernelPackage/qmi_wwan_q/description
qmi_wwan driver by Quectel
endef
EXTRA_CFLAGS:= \
$(patsubst CONFIG_%, -DCONFIG_%=1, $(patsubst %=m,%,$(filter %=m,$(EXTRA_KCONFIG)))) \
$(patsubst CONFIG_%, -DCONFIG_%=1, $(patsubst %=y,%,$(filter %=y,$(EXTRA_KCONFIG)))) \
MAKE_OPTS:= \
ARCH="$(LINUX_KARCH)" \
CROSS_COMPILE="$(TARGET_CROSS)" \
SUBDIRS="$(PKG_BUILD_DIR)" \
EXTRA_CFLAGS="$(EXTRA_CFLAGS)" \
$(EXTRA_KCONFIG)
define Build/Prepare
mkdir -p $(PKG_BUILD_DIR)
$(CP) $(SOURCE_DIR)/* $(PKG_BUILD_DIR)/
$(Build/Patch)
endef
define Build/Compile
$(MAKE) -C "$(LINUX_DIR)" \
$(MAKE_OPTS) \
modules
endef
$(eval $(call KernelPackage,qmi_wwan_q))
When I try to build it using the OpenWrt SDK I get the following error
make[4]: Entering directory '/home/crave/Documents/openWrt/openwrt-sdk-22.03.2-bcm27xx-bcm2711_gcc-11.2.0_musl.Linux-x86_64/build_dir/target-aarch64_cortex-a72_musl/linux-bcm27xx_bcm2711/linux-5.10.146'
HOSTCC scripts/basic/fixdep
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
HOSTCC scripts/sorttable
scripts/sorttable.c:34:10: fatal error: tools/be_byteshift.h: No such file or directory
34 | #include <tools/be_byteshift.h>
compilation terminated.
make[5]: *** [scripts/Makefile.host:95: scripts/sorttable] Error 1
make[4]: *** [Makefile:1209: scripts] Error 2
make[4]: Leaving directory '/home/crave/Documents/openWrt/openwrt-sdk-22.03.2-bcm27xx-bcm2711_gcc-11.2.0_musl.Linux-x86_64/build_dir/target-aarch64_cortex-a72_musl/linux-bcm27xx_bcm2711/linux-5.10.146'
make[3]: *** [Makefile:53: /home/crave/Documents/openWrt/openwrt-sdk-22.03.2-bcm27xx-bcm2711_gcc-11.2.0_musl.Linux-x86_64/build_dir/target-aarch64_cortex-a72_musl/linux-bcm27xx_bcm2711/qmi_wwan_q-1.2.2/.built] Error 2
make[3]: Leaving directory '/home/crave/Documents/openWrt/openwrt-sdk-22.03.2-bcm27xx-bcm2711_gcc-11.2.0_musl.Linux-x86_64/package/qmi_wwan_q'
time: package/qmi_wwan_q/compile#2.43#0.35#2.78
ERROR: package/qmi_wwan_q failed to build.
What could be the issue in this case and how could I correct it?
Thank you in advance
